Speed Sensor
Old Jun 21, 2013, 08:46 PM
relliart2004's Avatar
Speed Sensor
I have a manual 5peed 2004 Relliart Mitsubishi and it stops everytime it hits 3rpm then i would go up one speed then its ok until it hits the 3rpm again i would increase again. according to the check engine, the problem is the speed sensor. I tried locating the speed sensor but can't seem to find it. Do you know where the speed sensor's location and do you think speed sensor will fix the issue?
Old Jun 23, 2013, 04:05 PM
RacerX-Ralliart's Avatar
Not sure but it is on top of the tranny underneath the intake air hose
Old Jun 24, 2013, 08:55 AM
CrAnSwIcK's Avatar
it's on the differential housing on the tranny under the shifter cables, to remove it, you need to take the metal wire clip out, to get the connector off and it's held in by a 10mm bolt if i remember correctly. your car is in limp mode, does the speedometer work?
JohnBradley
Aug 26, 2019 11:13 PM
ChanceR
10
Aug 12, 2011 10:04 PM
krackerstache
Jul 8, 2011 11:50 AM
brokenRS
Mar 4, 2011 11:20 AM
EvoDan2004
Jul 14, 2008 06:30 PM
Quick Reply: Speed Sensor
