3 acd lights are on, dealer say its my bad speed sensor?
Old Mar 2, 2011 | 12:34 PM
brokenRS's Avatar
Have anyone encounter this problem? all my lights are on, they think its my bad speed sensor on the front right wheel.
Normally when the lights are on, i would think it is the acd pump.
Anyone?
Old Mar 2, 2011 | 01:37 PM
german_evoVII's Avatar
If your car is ABS equipped, then you should also see the ABS warning.
This will lead to an broken Wheel speed sensor.
If you dont have ABS, then do the short throttle test for the pump.
disconnect battery for app. 2 minutes in the evening ( or after driving the car to work ), then reattach it again.
let the car sit over night or during work, ( or a min of 2 hours )
Ignition on, DO NOT START
wait app.5-7 seconds
Push the throttle 100% for app. 5 seconds
Then the ACD Pump should start ( you will hear it in quiet areas), and running for 10-20 seconds, then shutting off.
If the lights going all on immediately, the Pump or the pressure sensor has an problem.
If the Pump doesnt start, check the fuse in the positive battery terminal or the relay at the firewall ( Cabling / connectors )
If the lights are going on when you start to drive the car ( moving more than 10 Mph ), then its one or more of the ABS sensors or sensor rings.
Old Mar 2, 2011 | 01:49 PM
sho669's Avatar
Yes, a bad wheel speed sensor can cause the ACD lights to come on.
Old Mar 3, 2011 | 11:21 AM
SwishaSweet's Avatar
if the pedals pushing back at you and stuff then speed sensor. You can just pull the ABS relay under the hood and the car should be back to normal once you reconect the battery
Old Mar 4, 2011 | 11:20 AM
brokenRS's Avatar
Well it wasnt the pump so i dont have to worry about that.
FL speed sensor and uneven thread wear from front and back was the cause of the ACD lights.
spin
Dec 22, 2018 09:21 AM
Michael Roestel
Sep 21, 2017 08:00 AM
Drsous
11
Apr 30, 2016 01:26 PM
Little G
Jul 3, 2010 09:56 AM
Cinci Turbo IX
Oct 26, 2007 09:57 PM
