ACD Question
Old Apr 27, 2016 | 02:59 PM
Drsous's Avatar
ACD Question
I recently swapped a 5 speed in my 9 mr car rides smooth. There is no t case whine or anything. All 3 ACD lights are on. Before the swap only 1 light was lit and I was able to to go through all 3 modes perfectly fine. Can anyone chime in on why all 3 lights are on?
Old Apr 27, 2016 | 03:15 PM
LetsGetThisDone's Avatar
Was the ACD line disconnected from the tcase during the trans swap?
Old Apr 27, 2016 | 03:33 PM
Drsous's Avatar
I believe so. I don't remember
Old Apr 27, 2016 | 03:49 PM
If it was, the ACD needs to bled.
Old Apr 27, 2016 | 05:15 PM
Drsous's Avatar
Ill try it this weekend. Will I cause any damage driving around like for awhile?
Old Apr 27, 2016 | 06:21 PM
CeliOnce's Avatar
Nope, but the front diff will effectively be an open diff instead of limited slip.
Old Apr 27, 2016 | 06:39 PM
Not the front diff. The center diff. And yes, it can cause damage. Unplug the ACD ECU or the pump so that it doesn't try to run with air in the fluid, or possibly no fluid..
Old Apr 28, 2016 | 08:37 AM
Drsous's Avatar
I drove the car today for a bit. Turn on the car the acd light came on and only one light was lit. After about 3 minutes of idling ( I always let the car warm up before I take off) all 3 acd lights came on. I know letsgetitdone said to bleed the system. I will try it when I get an extra hand but any other idea other than there is maybe air in the system?
Old Apr 28, 2016 | 08:55 AM
That's classic air in the system. It turns on, no issues from bad sensors or the pump motor being broken and not running. Tries to run the pump to build pressure, pressure doesn't build because of air, throws the lights on.
You don't need an extra hand, get a vacuum bleeder (even the hand pump ones work fine), and hook it up to the bleeder on the bottom of tcase and pull the fluid through. It's how I bleed mine, and it always works fine.
Old Apr 28, 2016 | 09:49 AM
Drsous's Avatar
I wish I could do that but I don't have any of the tools. I was going to do it the old fashion way. Turn the key to on the position and floor the gas pedal and have another person loosen the bolt
Old Apr 28, 2016 | 10:09 AM
You can buy a hand operated vacuum bleeder at Autozone or Oreilly's for $30...
Old Apr 30, 2016 | 01:26 PM
Drsous's Avatar
Bled the system today, drove for 30 miles and the only 1 light stay lit as it should. That's a lot letsgetthisdone! I appreciate your help! Now time to tackle my idle issue.
06MREvo
For Sale - Part Outs
34
Nov 18, 2014 01:05 PM
NOMIEZVR4
Oct 18, 2013 01:28 PM
DubsE46
Sep 11, 2012 12:03 AM
DubsE46
10
Dec 30, 2011 04:48 PM
