04-06 Ralliart Engine/Drivetrain (no forced induction)
4G69 Information/Cross References
Old Jun 29, 2008, 01:43 PM
  #31
PR_Mivec's Avatar
Originally Posted by Bryce89
So really all your saying is it i want to build my 4g69 all i would need a 4g69 spercific Cam shaft, crank and pistons. the rest i could use 4g63 stuff
Also just another question, take for example the honda boys using k24 block and a k20 head. would we be able to do the same? 4g69 block and a 4g63 head? using the 2.4L displacment and getting the legendary flowing capablity of a 4g63 head and 2 cams?
i retract from MY past opinios and state that yes you can put in a 4g63t head in on a 4g69 block and vice versa i saw this done on a mirage w/ "evo" engine (block read g69 on a g63 head
Old Jun 29, 2008, 05:01 PM
  #32
Cow town racer's Avatar
^ even if it can be physically done you will have a hell of a time trying to tune for the dohc. I don't think you will be able to get the ecu to work.
Old Jun 29, 2008, 05:19 PM
  #33
PR_Mivec's Avatar
i know that is why this kind of mods NEED a stand alone ecu to work, the case in point had a TECIII, remember this was a mirage not a modern lancer
Old Jun 29, 2008, 07:05 PM
  #34
fair enough
Old Jun 29, 2008, 11:59 PM
  #35
Bryce89's Avatar
Of course it would be done with a full stand alone ECU, Im not keen on piggybacks period.
Old Jul 21, 2008, 03:56 PM
  #36
Realistic's Avatar
so sourcing parts are easily found from a 4g63? main/head studs and such? and the only custom items would be valve springs, and such?
Old Jul 22, 2008, 12:18 AM
  #37
Bryce89's Avatar
You shouldnt need anything custom made, just about ever japanese tuning house has 4g63 stuff
Old Jul 22, 2008, 12:55 PM
  #38
RalliDew's Avatar
BUT THE VALVE TERRAIN ON THE 4G69 is one off for the 4g69 no other as of now.
Old Aug 6, 2008, 08:35 PM
  #39
LanEvo03's Avatar
so will putting the Evo head (4g63) fit on the ralliart block (4g69)
Old Aug 7, 2008, 03:00 AM
  #40
chowetime's Avatar
Doing this major mod can really open up a whole new level of performance I mean your options would endless - but which head do you put on this engine my thoughts would be that you could really only put the Evo9 head - not sure could be wrong,
The other thing that you have to ask is do you go N/A and raise the compression to 10:5.1. or go boosted and swap over pistons lower compression etc or have a go at putting in the Evo Stroker kit ?
Either way you would ditch the Fly by wire setup put a return fuel line (all of which can be donated via a EVO!!)
As for the ecu - I wonder if you could ditch the factory ECU and adopt the evo 9 ecuu and then add a PB unit! I mean you are basiclly recreating a 4G63T engine but with a larger displacement.
Old Jan 21, 2009, 06:35 AM
  #41
Ralliart_on_LSD's Avatar
this is an awesome thread. cant beleive it took me this long to find it. very helpful in my quest for 509whp. thanks.
Old Jan 31, 2009, 11:21 AM
  #42
So my rods cam in the mail. I'm going to post a picture now for you guys to see and compare our stock rods, and Eagle H-beam rods, for an EVO8 that fits our car perfectly. Some say we dont "need rods, and ours is already reinforced"
one look at this pictures tells a different story...
I'm going to post this up on a few other threads, just so it'll be helpful for others to search and find out info for our car.
Old Feb 1, 2009, 03:23 AM
  #43
chowetime's Avatar
And now we can see how Mitsubishi saved 100+grams on each rod as a weight saver..
Thanks for posting very interesting to see them side by side - but damn talk about the banana effect...
Old Feb 2, 2009, 09:57 PM
  #44
Realistic's Avatar
comments were too offtopic.
So as far as evo8/9 internals go... we won't be able to use evo pistons/mods?
but the head is fair game, as well as bolts/studs.. and springs?
Just curious what the advantage of using a 4g63 head, compared to a 4g69 head is.....
thanks again.
Old Feb 3, 2009, 01:53 AM
  #45
chowetime's Avatar
The advantage would be to be able to drop the compression and more available parts downside is that you lose CC
Quick Reply: 4G69 Information/Cross References
