A/C Compressor not turning on?
When I turn the A/C on, the fans kick on, but the compressor does not? I've searched for fuses, checked, swapped, etc., but I may be changing the wrong ones? Anyways, I've check the freon, and its near full. I dont get it? I've gotten under the car also, and its plugged in, I've unplugged, replugged.
So things I've done/checked:
1. Freon
2. Plug
3. Some Fuses
4. Re-filled Freon
5. Checked the plug with a meter, and nothing. Its not hot, no power.
P.S. - I recently threw a rod, and blew a hole in the side of my block, I was thinking of tracing the wiring and see if it maybe got cut somewhere?
1. Freon
2. Plug
3. Some Fuses
4. Re-filled Freon
Get A multimeter and pull the relay you should have 2 power & 1 ground that goes to the clutch and another that is computer controlled. Make sure it's koeo.
One thing I forgot is that the middle knob on the A/C settings in the car, the light is blinking. Any idea on how to check the relays?
mshilto89
Jul 21, 2016 01:41 PM
HKSevolutionNYC
Feb 2, 2016 10:27 AM
