2009 vs 2010 RA - Transmission Flush
Old Oct 18, 2013, 06:40 PM
Firaso17's Avatar
Since we don't have a Mitsu dealer in Windsor, ON...I decided to do my own SST transmission service on my 2010 Mitsubishi Lancer Ralliart at my dealer were I work at. After researching around about how to do it, the only results I found is 2009 models that has 3 drain plugs and how much the capacity it takes..etc.
The reason why I'm posting a thread about this is for the people who owns a 2010+ models, apparently 2009s have 3 drain plugs, the 2010 on the other hand has 2 drain plugs. The amount of drained sst fluid from the 2009 is approx. 7.8L ...however for my 2010 drained only approx. 5.2L - 5.3L (including the filter replacement)
as far as the fill up process, its the same as the 2009s
If you have any other notes to add please do so. Thanks
Old Oct 19, 2013, 08:35 AM
03chi-town0Z's Avatar
7.8 is the system capacity. The 2009 only drains around 5.5 L as well
Old Oct 22, 2013, 07:16 AM
Firaso17's Avatar
good to know that, because everyone seem to have a step by step process and claiming that's how much it drains...for the 2009s at least...but thanks for ur input
Old Oct 22, 2013, 05:17 PM
No problem. People on here sometimes drain the oil cooler and replace the filter, in addition to just draining from the plugs, which is why they may have larger volumes of drained fluid.
europaul
Feb 19, 2017 06:11 PM
ak47po
33
Mar 21, 2016 11:31 AM
trinibt65
Evo X How Tos / Installations
Aug 19, 2015 11:12 PM
Bom's Evo
71
Dec 10, 2013 04:32 AM
Quick Reply: 2009 vs 2010 RA - Transmission Flush
