Walmart Overfilled Oil.
Old Aug 24, 2012, 04:13 PM
Guest
Randal's Avatar
So I went to Walmart and they added 5.4 quarts of oil. When I measure it it is above the second line. On high rpm my breather filter is spitting out oil. What's the easiest way to remove some oil?
Old Aug 24, 2012, 04:15 PM
Mistaken's Avatar
You seriously let WalMart service your evo?
My god.
Drain some out... I dont know, try the DRAIN PLUG.
Old Aug 24, 2012, 04:18 PM
Thegame's Avatar
Yeah man, only use reputable shops. Not a discount store.
Old Aug 24, 2012, 04:20 PM
EvoM Community Team
golgo13's Avatar
You can crack the drain plug and loosen it enough to let some oil seep out or you can remove the filter and let the oil in the housing drain which is about 300ml (1/3 qt).
Just remember to put the filter back on...
boosted91t's Avatar
Pull the dipstick out, open oil cap and hold it on the rev limiter in 3rd gear.
Old Aug 24, 2012, 04:23 PM
JaYr_EvO9's Avatar
My god.
shrtstuff89's Avatar
Syphon it out of the dipstick pipe.
EvoM Community Team
golgo13's Avatar
FWIW I run one quart over factory spec in my track evo without issue, just gotta zip-tie the dipstick to the motor.
Old Aug 24, 2012, 04:24 PM
hatesposers's Avatar
Walmart is not the only place thats made this mistake. They dont figure that your oil cooler is part of that capacity and it doesnt drain out with a typical drain
Take it back to walmart. Have them drain and have them completely clean your engine bay.
Old Aug 24, 2012, 04:26 PM
Ive ran 5qts without issue. As for ziptie, use a spring to keep it in also, as cutting and replacing that ziptie everytime you check oil is a pita
Old Aug 24, 2012, 05:00 PM
Guest
Randal's Avatar
My god.
Uh yeah and my buddies with Evos and Isfs do too. Drain plug? Wow what's that? Lol, obviously...
Old Aug 24, 2012, 05:06 PM
Guest
Randal's Avatar
Perfect thank you, oil filter. I thought about that too.
Old Aug 25, 2012, 11:07 AM
adriano_917's Avatar
Reputable shop or walt mart? Do it yourself its really easy, that way nobody f$&? up your car.
Old Aug 25, 2012, 01:36 PM
4g63smokinall4s's Avatar
My god.
my thoughts
Old Aug 25, 2012, 08:13 PM
Mistaken's Avatar
You guys should learn to do it on your own. You shouldn't be shocked when Walmart ****s up your car.
You ask a dumb question and this is what you get.
Quick Reply: Walmart Overfilled Oil.
