Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
Noise coming from under car when going over bumps
Old May 2, 2010, 06:43 PM
Lucas03ES's Avatar
Alright so this has been going on for a while, but I have been tied up in my Galant too much to look in to it. Whenever I go over a bump, it makes a weird kinda bumping noise like something is loose under the car. It sounds like it is directly under the rear of the motor/firewall area, and it is quite audible. The car also jerks to one side once in a while, when I hit bumps, I do not know if that has anything to do with it. I also just had the car aligned and the inner tie rod ends done and the car had the noise before and still has it. Lets hear your ideas guys, thanks!
Old May 2, 2010, 07:01 PM
DannyGSX's Avatar
Maybe you have a cat or a small child stuck under your car.
Old May 2, 2010, 07:12 PM
03lances's Avatar
Anyways my guess would be the tranny mount that connects right where you state the noise is coming from, I guess if it was REALLY bad its possible the tranny could be moving enough to bind up the half shaft causing the jerk.
Old May 2, 2010, 07:14 PM
TurboTim06's Avatar
when u had the car aligned did they replace the tie rod that was damaged? did they check swaybar bushings or anything?
Old May 2, 2010, 09:59 PM
Lucas03ES's Avatar
I did not ask if they inspected anything. I will check the tranny mount and see what it looks like. Hopefully I will get some time in the next week or so to jack it up and make sure that cat I ran over isn't still stuck up there. Hopefully it didn't melt to my other cat. meow.
Old May 7, 2010, 07:33 PM
kkrproducts's Avatar
Another possibility is the sway bar linkages becoming loose due to wear. A friend's lancer had that problem.
Old May 10, 2010, 08:59 AM
blaze_125's Avatar
Originally Posted by kkrproducts
another possibility is the sway bar linkages becoming loose due to wear. A friend's lancer had that problem.
+1
Old May 21, 2010, 08:45 AM
fe2o3's Avatar
Can you try going over the bump with brakes applied and then again not applied? Mine has done this for years, but only if I hit the bump with no brakes applied. I'd think that would make it easy to figure out, but I've searched, tugged, tightened, pulled and can't find anything loose at all, but it keeps making a sort of metal rattle sound.
EvoIXPilot
36
Aug 8, 2018 08:03 PM
Jim3142
23
Jul 22, 2016 07:49 PM
Turbo Ghost
Sep 1, 2014 12:26 PM
Outie11
Outlander Sport
12
Jan 17, 2014 10:23 PM
eric6
Jul 22, 2012 11:02 AM
Quick Reply: Noise coming from under car when going over bumps
