Sponsored by:
Sponsored by: CARiD
What is the annoying rattling noise on the driver's front side???
Old May 31, 2011 | 11:43 AM
Turbo Ghost's Avatar
Unhappy What is the annoying rattling noise on the driver's front side???
It sounds like something is rattling on the front left side. I brought it to the dealership today and they heard the noise but can't find it.They checked everything and they found no loose parts.
It happens when I drive over uneven roads and/or small bumps at 30mph or less. It sounds like metal to metal rattling? This has been happening for a few weeks. Any ideas???
Old May 31, 2011 | 11:55 AM
Evo Tengoku's Avatar
Inside the car or outside? If inside, check behind the A-pillar cover.
Old May 31, 2011 | 12:36 PM
icethug's Avatar
It usually caused by the plastic dash rattling against window. Try holding down the dashboard next time it rattles to check.
Old May 31, 2011 | 12:41 PM
It's difficult to tell. It sounds like its outside, but maybe inside?
Old May 31, 2011 | 12:45 PM
I'll try this later.
Old May 31, 2011 | 03:46 PM
iceman1680's Avatar
I had a similar metal on metal sound that only happened around 1500 RPM. Turns out it was under the hood.
Old Jun 2, 2011 | 12:21 PM
teamnemesis3's Avatar
I have the same issues!! it's annoyin! until
I Blast the ROCKFORD sound system lol... try that
Old Jun 4, 2011 | 03:27 PM
kzlflash's Avatar
May be the pillar, may be the dash? I have a rattle in the rear right side that I haven't figured out where that is coming from. The shifter cable rattles when in 5th gear going over 65mph. The glove box rattles. It never ends...
Old Jun 4, 2011 | 05:35 PM
Crester's Avatar
Sadly that seems to be the ultimate Rattle Solution...
I hope Mitsubishi works on these rattling issues for future cars... we shouldn't have to chase rattles like this.
Old Jun 6, 2011 | 07:14 PM
garcias2k's Avatar
I have this on the passenger front, like metal rattling. Haven't looked to see what it is. Be nice to know.
Old Jun 7, 2011 | 09:16 AM
ptakats's Avatar
what did your problem end up being? my car does it at 3k and it sounds like a combo between a loose bolt and heat shield vibrating but i cant figure it out either, it just started
Old Jun 7, 2011 | 09:33 AM
gforced's Avatar
I know my panel under the steering wheel rattles at certain RPMs. Might check that one also. I have not got around to pulling this off to see what I can do to fix it.
Old Jun 8, 2011 | 04:29 AM
iceman1680's Avatar
This is the passenger side headlight. The arrow is pointing to a piece of metal that shakes under vibration. That was hitting my headlight when the RPMs would be at around 1500. I just tried my best to bend the metal closer to the frame of the car and no more rattle.
Attached Thumbnails What is the annoying rattling noise on the driver's front side???-rattle.jpg
Old Aug 17, 2011 | 10:00 AM
I give up. I can't find the rattle. It sucks.
Old Jun 27, 2012 | 02:39 PM
GGood82's Avatar
I have a rattle in the same area but as its a JDM on the RHS( Drivers ) .
After looking for weeks i have narrowed it down to where the Drivers front quarter panel joins the engine bay & is bolted in , pretty much where the hood sits when closed
If you look at it and tap the thing it sounds tinny and slamming the drivers door you can hear the rattle .
I wedged rubber/foam strips in there and it definatly stopped the noise however there are a few areas where it rests Metal on Metal.
Hope that makes sense ....
