AEM EMS Get tuning help for your AEM EMS system.
Ems Starting Fix For Evo Viii
Old Mar 1, 2005, 08:29 AM
TurbotrixRacing's Avatar
Everyone having problems with the start on the evo we think we've found the cure ..
Go to setup / sensors / cam crank sensor / advanced cam/crank
Under the options pull down ..
Where it says " Tooth time min " enter 500 ms
Where it says " Sync early " check the box ..
Let me know
Mark
Turbotrix
Big thanks to jason siebels from aem ... for helping with this on going prob
Old Mar 1, 2005, 08:32 AM
EVOTEXAS's Avatar
Oh man thanks! That will certainly help me later when I get an EMS! Woohoo!
Old Mar 1, 2005, 11:35 AM
Dutch's Avatar
That made no difference for me...
Old Mar 1, 2005, 06:09 PM
Dutch ..
try leaving the key in the one postion for about 3 sec,,then crank. Also in the engine start menu, set your fuel pump to prime for 3-5 sec. Try that ,,, what i noticed is ..it will take about 1 sec to sync for about 6 trys ..then on the 7th or 8th ..it will go back to 4 sec ... let me know
Mark
Turbotrix
Old Mar 1, 2005, 08:07 PM
bs
bs's Avatar
Works awesome!!!! I was already fairly happy with my start up as it would start after 4 or 5 turns and then come to idle perfectly even in cold conditions, but with this now it starts on the first crank!!! Sweet!
Old Mar 2, 2005, 09:27 AM
bs
bs's Avatar
For what it's worth I think this is more of a fine tuning detail. If your initial crank and warmup maps aren't set up near perfectly then this won't really help all that much with start up in my opinion. The AEM has taken a little while to tweek the driveability, but I can honestly say that the car has at least as good if not better than stock driveability.
Old Mar 2, 2005, 09:50 AM
GTVEVO's Avatar
I think you are exactly correct. You can maximize your startup crank by having all of the maps fine tuned in correctly first. But this will probably help along the way in addition, you just can beat good free information though so thanks for that!
Old May 10, 2005, 02:04 AM
pwerks's Avatar
These settings definitely can make a difference. Go ahead and try it everyone, just be sure to tune your maps well first.
Dave
Old Sep 6, 2005, 08:29 PM
awddyno's Avatar
I've tried this setting. Sometimes it starts in three crank rotation, sometimes six. Kinda annoying.
Old Sep 6, 2005, 08:41 PM
VTECH8TR's Avatar
I tried something that works but I'm not sure yet what it does to overall timing.
Sync Crank S Count --- ON
Sync Teeth --- 0
It starts right away but would this change anything else?
I don't know what that setting does, but with the options stated above my car now turns over in 2 turns 99% of the time. The Fuel and timing tables have to be setup pretty darn well to get the car to turn over easily.
Old Sep 13, 2005, 09:40 PM
awddyno's Avatar
new setting works for me, I've been driving on it for a week, and always has quick start up.
its a little different than what I originally posted. But noones interested since all your cars already have quick start up.
Old Sep 18, 2005, 04:17 PM
sterdyevo's Avatar
EVO 8 HARD TO START AEM EMS 1313U WITH 3.5 BAR MAP SENSOR. Go to setup / sensors / cam crank sensor / advanced cam/crank
DID NOT HELP ANY OTHER IDEA
Old Jul 19, 2006, 07:19 AM
forbidden color's Avatar
any idea on fixing my cold start?
it goes from 1500 rpm drops down to 500rpm, goes up and down until the engine warms up...
I don't know which setting this is doing..
Old Nov 6, 2006, 04:26 AM
AndyBandy's Avatar
worked for me!!! Thanks TT
Old Dec 8, 2006, 11:14 AM
32 psi daily's Avatar
cold start fix:
Let me know
Mark
Turbotrix
+ more fuel at warm up enrichment
+ Optima red top battery
that seem to work fairely well.
Quick Reply: Ems Starting Fix For Evo Viii
