Driving Techniques Discuss things like how to launch your car, or turn in points, correct steering position, etc.
2nd gear = slower shift for smoothness?
Old Aug 1, 2014, 07:02 PM
EBrown's Avatar
I would say it hesitates more while I'm accelerating. Does that sound right/normal? Again this might sound stupid but I'm very new to these cars and manuals in particular.
Old Aug 2, 2014, 09:48 PM
Jakee's Avatar
Originally Posted by kyoo
are you sure that's not a function of exactly how you're letting go of the throttle before you make the shift? i.e., depending on if you're steady state and let go, you were just accelerating a little and let go, were in the boost and let go,
Possibly; I'll definitely pay attention to this the next time I go out driving
Old Oct 16, 2014, 12:23 PM
AWDBOOST89's Avatar
Some weird issues, only thing I have noticed is on my IX MR is shifting into second from first will be notchy until the trans fluid warms up. Sometimes even after it will still be a little notchy, but if i do a quick pull and go through the gears carefully then it shifts very smooth. Maybe I need new trans fluid? I've heard that along with bushings..maybe even a front motor mount install would make it much better? Can anybody comment on that?
Old Oct 16, 2014, 01:36 PM
Kreeker's Avatar
Originally Posted by AWDBOOST89
Some weird issues, only thing I have noticed is on my IX is shifting into second from first will be notchy until the trans fluid warms up. Sometimes even after it will still be a little notchy, but if i do a quick pull and go through the gears carefully then it shifts very smooth. Maybe I need new trans fluid? I've heard that along with bushings..maybe even a front motor mount install would make it much better? Can anybody comment on that?
I experience the same thing... Till the transmission warms up I usually skip over 2nd because it's such a pain. I could be rolling at 5 mph and the transmission will still refuse to go into 2nd gear. Makes me want to cry.
Oh the light just turned green and you're slowly rolling? FU I will not let you shift into 2nd. I either have to almost completely stop and shift into 1st or slip into 3rd...
Old Oct 16, 2014, 05:10 PM
Robevo RS's Avatar
Both of my X GSR shift perfect, i dont need to slow or do a different selection with any gear , besides the revers.
Old Oct 16, 2014, 05:18 PM
.M.
.M.'s Avatar
3rd gear is notchy for me (normal driving). If I shift slow, it's smooth. No problems with spirited and track.
Old Oct 22, 2014, 11:54 PM
vr4gasmtt's Avatar
Did you ever get this figured out? I have the exact same issue.
Old Dec 29, 2014, 09:45 AM
leamags's Avatar
my shifts are pretty smooth - maybe its something in the clutch? you should prob check that out though with your mechanic
Tmracer22
Oct 31, 2015 03:43 PM
PriusRepellent
Sep 18, 2015 05:39 PM
waterlooLancer
26
May 17, 2012 08:55 AM
johnnycage
20
May 11, 2012 01:20 PM
edIT
Mitsubishi TC-SST Discussion
May 6, 2012 07:14 PM
Quick Reply: 2nd gear = slower shift for smoothness?
