E85 longevity
Old May 9, 2016, 08:17 PM
kaj
kaj's Avatar
E85 longevity
Anyone have an idea of how long it can sit in our tanks before going bad? My car won't start and that's the only thing I can think of. It does smell different.
I haven't checked the injectors for goo, but I will before draining the fuel.
Old May 9, 2016, 09:23 PM
whtrice's Avatar
Well first of all how long has your car been sitting? I have had fuel (E-85) sit for 6 to 8 months in a tank with out any problems.
Old May 9, 2016, 10:18 PM
RazorLab's Avatar
Received 1,038 Likes on 760 Posts
Same, I highly doubt it's the fuel. Recheck all your connections and fuses.
kaj
kaj's Avatar
It's been sitting for three months without running. I think the tank was about a month old before i parked it.
The only thing i swapped were some S1 cams. The timing is spot on, so i'll re-check the sensor triggers.
gracias for the info.
Old May 9, 2016, 10:23 PM
RazorLab's Avatar
Check the cam sensor, won't start if bad or disconnected.
Old May 9, 2016, 11:05 PM
kaj
kaj's Avatar
They're both plugged in. I'll check the triggers on the cams. They only go one way, but maybe I messed up, somehow.
I just went out and tried again. The car kinda stumbled a few times then backfired, so I stopped LOL. Plugs were a bit wet and smelled like fuel.
Old May 10, 2016, 09:20 AM
lancerrally45's Avatar
I wish I would have seen this before yesterday. I had a 5 gallon tank full of e85 that was sitting for over a year. Needless to say I needed regular so I got rid of it. When I was disposing the gas in an environmental way I noticed the color had changed. I cannot speak to the volatility of the e85.
With that being said Ethanol is extremely hygroscopic. If the tank is sealed and no water is in the system, there really is not a shelf life. I have heard of people building their cars over the winter and starting it up in the summer time with the same tank of e85.
Your issue does not sound like fuel. It sounds like the timing is off in one way or another. Double check all sensors.
Funny story, back when I was learning about cars, one time i installed my crank sensor backwards on my old lancer. Car wouldnt start. Im such a noooooob.
Old May 10, 2016, 09:31 AM
Biggiesacks's Avatar
are you switched to the E85 map? This might be a kind of "Duh of course biggie" but sometimes its the little things that slip through so i thought i would throw it out there.
Old May 10, 2016, 10:06 AM
Klaiceps's Avatar
I'm guilty of that. Whenever an issue pops up I'm always thinking of the most complex solution to fix it.
Old May 10, 2016, 10:48 AM
lghtngyello03's Avatar
If you swapped cams, try checking the orientation of the cam trigger wheel, it's possible that it can be 180 out.
Old May 10, 2016, 11:06 AM
kaj
kaj's Avatar
LOL I did NOT switch. But it will usually start.
Duh.
Ill swap maps and check back. Hahahaha
Old May 10, 2016, 11:33 AM
Duh.
We all have our noob moments. Embrace it
Old May 10, 2016, 12:17 PM
kaj
kaj's Avatar
I never have them [/sarcasm]
Yeah... I have 1450s on stock scaling, so...LOL
Old May 11, 2016, 06:36 AM
Lol good to hear you found it.
Old May 11, 2016, 11:02 AM
kaj
kaj's Avatar
Problem solved.
Gas still smells funny, though LOL.
Quick Reply: E85 longevity
