openport 2.0, ecuflash 1.41, and evolution 9, not working!
Old May 11, 2009, 08:51 AM
voltexct9a's Avatar
hey guys..
have a small problem hope you guys can help me out with
i recently purchased the openport 2.0 from tactrix and downloaded the ecuflash 1.41 program.
i plug the head of the tactrix cable into the obd2 port as well as the evo 9 connector but ECUflash is unable to read anything. comes out the error code which says 'unable to read from ECU' or something like that.
am i connecting the plugs wrongly or do i have to download a definition file or something like that?
thanks in advance for any help!
Old May 11, 2009, 09:31 AM
voltexct9a's Avatar
this is the error im getting
Old May 11, 2009, 12:15 PM
evonut270's Avatar
has it been remapped?try running ecu unlocker first then open ecuflash and try again.
Old Jun 26, 2009, 05:51 AM
poombah's Avatar
i having same issue:
[20:50:04.076] EcuFlash Version 1.41.2483
[20:50:04.076] OS Version Windows XP
[20:50:04.076] Qt Version 4.4.0
[20:50:04.086] 26 memory models read.
[20:50:04.086] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[20:50:04.376] 345 ROM metadata models scanned.
[20:50:04.376] checksum module "subarudbw" loaded.
[20:50:04.376] checksum module "mitsucan" loaded.
[20:50:04.376] flashing tool "wrx02" loaded.
[20:50:04.376] flashing tool "wrx04" loaded.
[20:50:04.376] flashing tool "sti04" loaded.
[20:50:04.376] flashing tool "sti05" loaded.
[20:50:04.376] flashing tool "mitsukernel" loaded.
[20:50:04.376] flashing tool "mitsukernelocp" loaded.
[20:50:04.376] flashing tool "mitsubootloader" loaded.
[20:50:04.376] flashing tool "shbootmode" loaded.
[20:50:04.386] flashing tool "shaudmode" loaded.
[20:50:04.386] flashing tool "subarucan" loaded.
[20:50:04.386] flashing tool "mitsucan" loaded.
[20:50:41.420] J2534 API Version: 04.04
[20:50:41.420] J2534 DLL Version: 0.50.2464 (DEBUG) Jan 29 2009 10:58:58
[20:50:41.420] Device Firmware Version: 1.06.2536
[20:50:43.282] sending init sequence 1 (0001)
[20:50:46.567] sending init sequence 1 (0003)
[20:50:49.862] sending init sequence 1 (FFFF)
[20:50:53.137] sending init sequence 1 (F0F0)
[20:50:55.860] no response to any known code
[20:50:55.870] interface close
Old Jun 26, 2009, 12:56 PM
ohhgyeahfasho's Avatar
I used to get the same thing when tuning with a low voltage battery, try starting the car and leaving the car on for 20 seconds and then try flashing then(with Ecu unlocker). If that fails, check the battery voltage at a local autozone its free, and they also recharge batteries for free. Also, check if the cable is working by using EvoScan and try to log your car.
Old Jun 26, 2009, 12:57 PM
GST Motorsports's Avatar
If those are ecutek'd evos you need to use the unlocker...
Old Jul 6, 2009, 07:49 PM
burnzy's Avatar
a few of us have had the same problem, it's the reflash connector not making contact inside the aux port. try stick a wire or something up there and it'll work.
Old Jul 8, 2009, 11:00 PM
Mike01gsr's Avatar
Had this problem, was my damn mini battery not having enough juice! Thank God I found this thread!
Old Jul 8, 2009, 11:21 PM
heel2toe's Avatar
I had a problem similar to this. Ecuflash would not recognize that my cable, the openport 2.0 was plugged in. It turned out to be a simple software driver issue in my case. That may be your problem. Check it out.
Old Jan 20, 2016, 09:49 AM
danfalcas's Avatar
I already updated all the drivers. might try to use a different computer
Old Jan 20, 2016, 12:55 PM
hearnoevo's Avatar
ecu
let's start with the basics. Is the engine on when doing the read or is the key in the on no crank position?
Old Jan 22, 2016, 04:52 PM
Raptord's Avatar
What's the battery voltage when you're trying to connect?
Old Jan 22, 2016, 05:23 PM
Ians06's Avatar
I beleive the voltage varies internally to the tactrix cable..something between 12-19v if im not mistaken, so you cant just put battery voltage on on the littlle 2.5mm jack.. That is the same message I get when I try to connect but forget to plug in the mini 2.5mmconnector. Also I just made my own connector with parts bought from Radioshack. Probably a bad connection. Good luck!
kimmerlykg
Apr 15, 2017 03:48 PM
usernameka
Apr 9, 2017 09:30 AM
Evodetailer123
Oct 3, 2016 07:37 AM
Mitsu.kid.02
Lancer Engine Management / Tuning Forums
217
May 25, 2016 10:47 AM
Me-So-Bishi
13
Sep 24, 2010 03:32 AM
Quick Reply: openport 2.0, ecuflash 1.41, and evolution 9, not working!
