Evo anti-lag ECU disassembly
Old May 11, 2007, 09:55 AM
  #31
jcsbanks's Avatar
Probably just not defined since I think it is only me that has been making JDM VIII xmls.
Old May 11, 2007, 01:11 PM
  #32
C6C6CH3vo's Avatar
Oh
Old May 11, 2007, 02:43 PM
  #33
jcsbanks's Avatar
I'm wondering if the leaning and advancing that goes on is a lean burn setup to try to save fuel? It would make sense that it needs to go back to stoich occasionally to see where stoich is?
Old May 11, 2007, 03:04 PM
  #34
EvolutionBoy67's Avatar
Here is my question? Will this work only with the stock turbo or could this work with aftermarket turbos, both stock location turbos and rotated mount turbos.
Old May 11, 2007, 03:26 PM
  #35
jcsbanks's Avatar
Anti-lag should work with anything that can go onto the stock exhaust manifold that has the SAS ports and a turbo that won't melt
The settings I used to test this are very subtle and just give a few rumbles in the exhaust on lift off, not sure it really makes a huge difference to lag. I'm not running it any more beyond a simple test.
Old May 11, 2007, 07:08 PM
  #36
C6C6CH3vo's Avatar
Is there a chance that several of the "antilag" tables (BE Enrich/Enlean, and adv/ret) actually do something else like emmissions or like you said, milageand perhaps need a title revision?
Which maps are intended to assist true antilag fitted evos and which ones just assist boost (or try to ) for USDM ?
Old May 12, 2007, 12:58 AM
  #37
jcsbanks's Avatar
I think the only stuff related to anti-lag is the stuff I showed in my image on page 1 directly related to the SAS valve.
I think all the lean spool/BE/adv/ret stuff is economy/emissions.
Old May 12, 2007, 10:32 AM
  #38
mrfred's Avatar
Before my vacation over the last two weeks I disassembled the code in my IX ECU that controls the secondary air solenoid. I'm not sure on the units for time because timed events go deep into the timer units on the SH2.
Can you post up your ECUFlash definitions for all the tables/constants?
Old May 12, 2007, 12:21 PM
  #39
burgers22's Avatar
Hi
Can you post the XML for this, I'll have a go at finding the maps for the JDM 7, unless someones already there. Thanks.
MB
Old May 12, 2007, 01:13 PM
  #40
jcsbanks's Avatar
<scaling name="RPMstatbyte" units="units" toexpr="x*31.25" frexpr="x/31.25" format="%.0f" min="0" max="11000" inc="1" storagetype="uint8" endian="big"/>
<scaling name="Timesecbyte" units="s" toexpr="x/10" frexpr="x*10" format="%.1f" min="0" max="25.5" inc="1" storagetype="uint8" endian="big"/>
<table name="ALS minimum vehicle speed to trigger" category="Turbo" address="1e12" type="1D" level="1" scaling="VehicleSpeed"/>
<table name="ALS minimum coolant temperature to trigger" category="Turbo" address="1e14" type="1D" level="1" scaling="Temp"/>
<table name="ALS minimum RPM to trigger" category="Turbo" address="1e16" type="1D" level="1" scaling="RPMStatLimit"/>
<table name="ALS minimum load to trigger" category="Turbo" address="1e18" type="1D" level="1" scaling="Load16"/>
<table name="ALS minimum time to trigger" category="Turbo" address="1e1a" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS trigger valid time" category="Turbo" address="1e1c" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS Load below which active" category="Turbo" address="1e1e" type="1D" level="1" scaling="Load16"/>
<table name="ALS active time limit" category="Turbo" address="1e20" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS Delay before air injection" category="Turbo" address="1e22" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS Delay before fuel injection" category="Turbo" address="1e24" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS Fuel injector time" category="Turbo" address="1e26" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS Air injection time" category="Turbo" address="3fe0" type="2D" level="1" scaling="Timesecbyte">
<table name="RPM" address="66d8" type="X Axis" elements="9" scaling="RPM"/>
</table>
Old May 12, 2007, 01:35 PM
  #41
Oracle1's Avatar
Bang Bang away.......
Old May 12, 2007, 02:48 PM
  #42
mrfred's Avatar
In the ECUFlash ROM definitions, is the so called "Boost Enhancement (Anti-Lag) Start RPM" not what it claims to be, and instead is actually just the lean spool start RPM?
Old May 12, 2007, 02:57 PM
  #43
Oracle1's Avatar
yep
Old May 12, 2007, 02:58 PM
  #44
jcsbanks's Avatar
Yes.
Old May 13, 2007, 01:39 PM
  #45
C6C6CH3vo's Avatar
I disabled Lean spool by changing 2 to 4 on the stop and made RPM same as start.
Do ya'll think the funky antilag timing and fuel maps kick in when EGR responds to NOx's? I guess I can partly confirm by riching the fuel maps to 14.7 and seeing if I still get those 15.7 AFRs @ 60% load/2000-3000rpm since I have no cat and the rear O2 is dummied
Quick Reply: Evo anti-lag ECU disassembly
