ayc/acd bleeding
ayc/acd bleeding
is it possible to replicate AYC/ACD bleeding technology of the MUT3 mitsubishi tool with openecu cable? maybe someone has done any research in that area?
as you probably know our cars have somewhat weak clutches. when reinstalling them, ACD/AYC bleeding may be necessary. also, the original tool to do that costs somewhat like $5000. i thought this would be of help to many evo owners. please share if you know more on this.
usdm evo's don't have ayc, im in Scotland myself and my evo runs ayc, theres two parts to ayc/acd servicing:
the diff oil is simple drop old oil - drop new in etc
the oil which needs the mut3 tool is the ayc oil which on 7.8.9s in left side in the boot, this according to mitsu needs to be changed ever 4.5k miles with the mut3 tool.
however that is a load of crap, mitsu only done this 4.5k interval as there was a recall on a particualar issue with ayc on some cars, so as it was cheaper for them and made them more money they changed the ayc service interval from 9k to 4.5k.
even changing the ayc oil every is really not needed, unless you screw your car very badly and i mean like track days where heavy use of ayc is required.
i havent changed my ayc oil for around 10k miles and dont intend to till a further 5-10k, the oil should be a dark purple coloured fluid.
it wont get used so should never need to top up, it gets circulated around the clutch plates hence over time and hard use will devlope small bits from friction, this is when you should change it, but believe me it takes a lot of track days to make this happen.
on the models that do have AYC, the ACD/AYC use the same pump.
going full throttle w/ the key on should prime the pump for a few seconds, bleeding this way worked for me when i had the FQ-340 over here.
Jared Murphy
14
Mar 7, 2017 11:02 AM
BoostNY
Apr 5, 2016 05:23 PM
