Need Experienced Log Readers 2.0 or 2.3 Log?
The 4 3/8 is the TDC. Now you need the measurement for the BDC. Then subtract one from the other and turn the result into millimeter for your answer.
The BDC is the real measurement we need here as that's the one that relates to your stroke and how far the piston is traveling from your measuring point.
Considering your block is indeed a 4G63 block... 88mm means its a 2.0L and 100mm means its 2.3L. There's also a 94mm and a 102mm option if I remember correctly but the chances of you having either of them is unlikely.
Be sure to let us know, cause I'm curious.
Ah I see now
And tge above stated is entirely correct
So please get back to us with the final measurement needed to confirm displacement
Im curious as well
Im curious as well
KK
May 24, 2005 11:18 AM
WestSideBilly
Site Feedback / Suggestions
16
May 2, 2003 08:16 AM
