Built 2.0L ETS t4 twinscroll 6266 S2 cams Skunk2 94oct
Old Aug 26, 2013, 02:57 AM
tscompusa's Avatar
This is the car in the video c0ke posted in his thread. This is his buddy. They are both running the same quality 94octane fuel from Canada.
After going from a modded walbro, to a walbro 450, we kept running out of fuel. He then switched to a double pumper and everything was good to go.
I edited this thread to keep it simple so the latest results are below.
Mod list is:
Built 2.0 stock compression (wiseco 1400hd/MAP Rods)
GSC S2 - supertech springs/retainers
ETS twin scroll T4 6266 ball bearing 1.15AR Turbo kit
precision 1000cc injectors
Buschur Double Pumper
Skunk2 ported intake manifold
Skunk2 68mm throttle body
ETS 3.5" FMIC
ETS intercooler pipes
Tial Q BOV
speed density - omni 4 bar - gm IAT
spoolinup COP
Quartermaster 8 leg street clutch
Tephra v7 SD /w mbc
Engine bay pic:
At 31-32psi the car produced almost 600whp.
For reliability and safety purposes I completed the tune at 30psi and that is where we kept the final tune boost pressure at:
Old Aug 26, 2013, 04:12 AM
car_nut15's Avatar
Thanks for posting this Tom! I'm happy with the results so far. I should have known the walbro 255 was going to be the limiting factor. As soon as I figure out what I'm going to do for a fuel pump and replace this stupid mini battery I'm hoping we can hit the goal of 600. Thanks to Tom for being patient and doing a great job.
Old Aug 26, 2013, 04:44 AM
V8HAHA's Avatar
Nice job TOM as usual. Are you guys going to do injectors also when the pump is up graded. I'm running 1650s(E85) which I think is going to limit my whp. I see your on 94oct which is different but if your going to do pumps why not injectors for future changes( turbo, cams or even E85).
Old Aug 26, 2013, 04:46 AM
car_nut15's Avatar
Unfortunately in Canada E85 is non existent. If I remember correctly, Tom said the injectors should be just fine for my goal.
Old Aug 26, 2013, 06:00 AM
HsamehH's Avatar
seems the S2 and 1.15 a/r is a good combo tom s3 would make more but this seems to spool pretty good.
Old Aug 26, 2013, 09:14 AM
nwa7265's Avatar
Has the t4 twin scroll helped with spool at all? I'm thinking of going with a t4 twin scroll but with a 1.0 hotside on a 6466.
Old Aug 26, 2013, 10:58 AM
Boosted Tuning's Avatar
Good stuff Tom. I love Canada's 94 oct. Its some good stuff.
Old Aug 26, 2013, 01:31 PM
211Ratsbud's Avatar
Do you know who ported the skunk 2 mani?
Old Aug 26, 2013, 02:59 PM
car_nut15's Avatar
Ported by Maperformance
Old Aug 26, 2013, 10:36 PM
tscompusa's Avatar
Glad you're happy! once we get more fuel we should be able to reach our goal hopefully safely
Ya the s3 will make more, but they will lag it a lot downlow because its only a 2.0L
Twinscroll usually always helps spool. I might be able to compare another cars spool with this one if i can find something with S2's which im sure i can on a 2L.
Thanks Jay. ya it definitely works really well.
Old Aug 27, 2013, 04:57 AM
Silvermike's Avatar
spools about 100-200 rpm later than my SS 5858 on stock 2.0L
Old Aug 27, 2013, 10:59 PM
tscompusa's Avatar
If you want Mike i can overlay the two if you are interested in seeing the data.
Old Sep 5, 2013, 10:17 AM
el.guerrero's Avatar
Interested on the overlay too.
Old Sep 5, 2013, 03:20 PM
mitsubeastlee's Avatar
Interested in OVERLAY PLZ tom!
Old Sep 5, 2013, 06:09 PM
Airflow86's Avatar
This is pretty much the setup I want to run. How well would this kit do same mods on CA91? Or is it just hopeless making decent power on this garbage fuel?
Quick Reply: Built 2.0L ETS t4 twinscroll 6266 S2 cams Skunk2 94oct
