Coolant Overflow tank.
Old Mar 19, 2007, 08:57 AM
DsmAwdTurbo's Avatar
I should know the answer to this but unfortunately i dont. Here is the deal. I just replaced my head gasket and head studs cams springs and retainers. I did get some coolant in the engine bay, but this is whats happening. First off let me start by saying i blew the headgasket months back and got a new head under warranty. After i got the car back i did smell coolant but it didnt seem to be burning. There is no white smoke coming from the exhaust and you cant smell the sweet coolant smell. All you smell is gas. The question at hand is about the overflow tank. When the car is running the overflow tank fills up, when the car is off the overflow tank goes down slightly. I remember on my dsms that this was the case. The burning coolant smell is annoying and it seems to only be pronounced when the fan is on. I am going to do a coolant system pressure test this afternoon but I wanted some input on the overflow tank. IS THIS NORMAL haha. I should know but I dont. Any inputs are welcome and appreciated. Thanks in advance
-Anthony
Old Mar 19, 2007, 09:24 AM
Paul Nelson's Avatar
How long has it been running for since you installed the new gasket?
What i would do is drain the coolant overflow and than run it hard under boost. Than see if it fills up if it does its the headgasket
Im pushing a little bit about 40lbs of boost so were going to pull the head gasket and install the new ams studs http://www.amsperformance.com/main.php which allow us to torque down more
Old Mar 19, 2007, 10:20 AM
the strange thing is this. you have tha max and mix marks on the overflow bottle. Well I marked the spot that its at when the car is on, and i marked the spot that it sits when the car is off. It never changes. when the car is on the coolant sits in the overflow at the same level and when the car is off it sits at that level.
Old Mar 19, 2007, 10:34 AM
are you burning coolant?
Old Mar 19, 2007, 06:14 PM
barneyb's Avatar
You either have a bad radiator cap or the hose to the bottle isn't sealing.
Also, since no coolant is expelled when the engine is hot the cooling system is low.
evrblazin
Apr 14, 2010 08:44 PM
MurphDurph
Lancer Aftermarket Forced Induction Tech
21
Dec 29, 2008 06:36 PM
Johnboy1065
12
Jan 28, 2008 01:38 PM
naucrx
25
Jun 28, 2007 02:11 PM
mac_05evo
19
Jul 7, 2006 06:22 AM
Quick Reply: Coolant Overflow tank.
