Exedy twin...kinda problem..
just installed my exedy twin ... still in break in period..
once i stop its hard to get into 1st gear..i have to push it hard and force it in...sometimes it even hard to get into any gear..
this only happens when i am at full stop...once the car is rolling...everything is nice, smooth and perfect..
any insights?
thanks
any insights?
thanks
Adjust your clutch pedal just a little more out. Mine is only showing 1 thread remaining... I even adjusted it out to showing 0 threads the other day but just made things a little worse. Trust me, 1 threads makes a whole lot of difference.
guys...i tried adjusting every position possible...some had better results than the other however..it is still hard to get it into gear from the stand still..especially after the car is warmed up..
any more advice?
any more advice?
is your clutch new or has it already been broken in?? mine is brand spankin new..just about 180 miles on it...still havent gone past 3500rpm...
its kinda annoying...true what they say..performance comes with a price ...
adjusting the clutch peddle out means more threads are showing, not less. You've started numerous threads about how your clutch went from great to troublesome. You should figure your issues out before offering advice, don't you think?
mine is broken in. its really annoying. The only difference is mine is near impossible when cold but gets a little better as it warms up. I have moved the adjustment around so much i dont know what to try next.
Adjusting the clutch pedal out, turning the rod clockwise shows less threads. And my threads are opposite. They went from bad to getting better, just not perfect like im wanting yet.
Dont you love it when someone thinks 'they got you'.
