ACD Tuning Options - USDM CT9As, Read!
Old Oct 14, 2016, 08:26 AM
  #496
kyoo's Avatar
Originally Posted by aamoedo
Has anyone confirmed if the acd units are vin specific? Or could I buy an eBay one and send it in?
they are not vin specific as far as I know - any 8/9 acd ecu will work with any evo 8/9
Old Oct 14, 2016, 02:55 PM
  #497
tscompusa's Avatar
Originally Posted by Casey Robertson
Tom, best way to get in touch? I see ACD ECU's on eBay - I have a 2005 GSR. Thanks
Casey
Here or tscompusa@gmail.com I had to renew my vendor status that's why it wasn't letting anyone PM me on here.
Originally Posted by kaj
+1 I PM'ed you back, Tom, regarding my paypal info for the invoice, but EvoM says it's unable to send you the message.
Let us know. Thanks!
@tscompusa
Resend the messages please.
They are not, like Kyoo mentioned.
Originally Posted by 555R
hey ts comp
have you made any new ACD maps since i pick up ACD mapping from you ?
I still have an extra ACD ECU i can send if there are new maps made...i pretty much run the number 1 map out of the 3 i got, i guess its the dry map.
let me know if there are any new mappings you have and pm info where to send and cost etc.
fyi
I've had the TSCOMP reflash i think two years now along with the restocked rear lsd and full urethane bushings, corner balance and coil over height adjustments.
the car is mad. the way every evo should be...i think an more aggressive lsd is the only next step i have.
We do not have anything new, But we can adjust stuff custom if asked.
Old Oct 17, 2016, 01:12 AM
  #498
555R's Avatar
I wouldn't even know what to adjust for the acd. I do know I don't even use the stock maps anymore because they feel pretty flat compared to the new maps I got from you.
Maybe I'll just sell my original acd ecu. Or keep it as backup and send it to you reflashed as a backup.
Old Oct 17, 2016, 05:42 PM
  #499
tscompusa's Avatar
555R its pretty good as it is. Id like Kyoo to test my code ill give it to him for free to review it if hes up for it. For the most part they all perform the same though. There's only so much you can do to improve the car.
Old Oct 17, 2016, 09:40 PM
  #500
kaj
kaj's Avatar
payment and ECU sent. If I get it back before my two-day event in Nov, I'll write up a review.
Old Oct 18, 2016, 06:20 AM
  #501
kyoo's Avatar
where are u guys getting your spare ACD ECUs?
Old Oct 18, 2016, 01:42 PM
  #502
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
Ebay
Old Nov 23, 2016, 06:57 PM
  #503
Laxman's Avatar
Right now EBay has ACD ECUs for less than $50 shipped
Old Nov 23, 2016, 08:07 PM
  #504
kaj
kaj's Avatar
I have a perfect ACD ECU out of my car. $45 shipped, obo?
Old Feb 17, 2017, 07:17 AM
  #505
kyoo's Avatar
bumping this for everyone getting ready for the spring
Old Feb 17, 2017, 07:40 AM
  #506
kaj
kaj's Avatar
I have a new shortblock going in, along with a Weir 12-plate in the rear. THEN I'm ready. Shooting for GTA at SOW.
Old Jun 23, 2017, 02:08 PM
  #507
kyoo's Avatar
was reading this article by motec from 2013 - pretty awesome results and give some insight into how the ACD should be set up - as I thought, more lock on braking, more open on corner entry/turn in, more lock on exit
http://www.motec.com/filedownload.ph...pdf?docid=4399
worth noting a few things:
Lap times, Evo X RS (Winton Raceway)
Fully locked 50:50 1m:36.9sec
Fully open (no control) 1m:35.8sec
Tuned diff (mixed values) 1m:35.1sec
I believe the evo X RS does not have AYC OR ABS, which could be a big factor. note that with the ACD set to open, how much oversteer is added into the car. this is corollary to what we've seen in our ACD improvements.
This is especially crucial for our USDM cars, which never got AYC, to compensate for that turn in/removal of understeer/push. More oversteer into corner entry, check. More lock under brakes allows stability, and as noted they go near full lock on acceleration and it practically allows the car to power oversteer without an aggressive or active rear diff.
Can't stress again how crucial this is for our cars. With the factory ACD setup + a mechanical diff on the USDM 8/9, what you're going to run into is understeer on corner entry and fwd like behavior. the ACD needs to be tuned to allow for faster turn-in & corner entry + some oversteer.
From what I could tell, early aftermarket ACD options just increased the lock period. These newly tuned ones have really improved the setup here to allow for optimal performance for corner entry, braking, and acceleration.
codgi (Jun 23, 2017)
Old Jun 23, 2017, 02:43 PM
  #508
kaj
kaj's Avatar
I definitely wasn't taking full advantage of the re-tuned ACD in my car during my last track day. I could have braked later and harder as well as powered out of turns sooner. I was being too easy on it.
I can't wait for another try.
Old Jun 23, 2017, 02:47 PM
  #509
kyoo's Avatar
yea honestly those are "added" benefits to me. the biggest thing I wanted to address was the understeer on corner entry that USDM cars that the euro cars did not have.
Old Jun 23, 2017, 02:54 PM
  #510
kaj
kaj's Avatar
I tuned that out long ago. It's a DEFINITE help!
Quick Reply: ACD Tuning Options - USDM CT9As, Read!
