Help! Noise After timing belt!
Hey guys I just got done changing my timing belt, balance belt, and accessories belt but now I am getting a very odd noise like a bearing is about to go. Both of the belts spin freely and do no heat up at all. Also, all of the pulleys including the water pump were changed and everything was torqued. I have never experienced this noise before when performing timing belt jobs but there's a first time for everything right? This is my daily driver for work and school so I need to get the car running ASAP!
http://s1024.photobucket.com/albums/...205_212919.mp4
Not sure if you know this trick but get a long screwdriver or prybar and put the metal end on the alternator housing. Then put your ear on the handle end to listen for bearing noise. Move to every component until you pin point the noise. The one that's bad will be noticeably louder.
If it sounds like bearing noise, acts like bearing noise, must be bearing noise, right?
Poke around to see if you can hear it, but if it's anything on the block I'd be afraid to poke around there with that belt moving. You could try taking the belt back off (yeah, I know, shoot me) and seeing if any of the pulleys feel loose, don't turn as they should, or make noise when you spin them.
Everything you replaced with bearings in it is immediately suspect too. New parts can be bad out of the box.
Sounds kind of like a bearing but almost like there is something bouncing around in there. Any screws drop into anywhere? How are you balance shafts? Lined up? My oil pump balance shaft was flipped 360 but didn't sound like that. Use a screwdriver like the person above mentioned and put one side to your ear and the metal part on various parts in the engine bay. Where is the sound coming from, top or bottom of the motor? Also one more thing to check would be the auto tensioner, did you re-adjust? Even the new ones have to be adjusted
Your balance belt is 180 out..... thats the whine noise, that or your belt is to tight. But I have a feeling your balance shaft is 180 degrees out. Did you put a screw driver in the block to make sure it was at the correct position?
As I have stated above my balance shaft is not 180 degrees out. The timing belt isn't too tight because I ran the car before putting it all back together. The belts aren't heating up either and spin freely. Can the tension be adjusted on the serpentine belt?
Did you replace/ remove the lifters?
can you make the noise go away by removing the serpentine belt?
Is it possible the lower timing cover is installed a little crooked and is rubbing on one of the belts?
is the crank trigger wheel installed correctly?
is it possible the crank position sensor came loose?
SoSoEVO (Jun 16, 2020)
[QUOTE=MuslimEvoFreak;9943688]Hey guys I just got done changing my timing belt, balance belt, and accessories belt but now I am getting a very odd noise like a bearing is about to go. Both of the belts spin freely and do no heat up at all. Also, all of the pulleys including the water pump were changed and everything was torqued. I have never experienced this noise before when performing timing belt jobs but there's a first time for everything right? This is my daily driver for work and school so I need to get the car running ASAP!
http://s1024.photobucket.com/albums/...205_212919.mp4[/QUOTE
Hey mate I had a horrible whine after doing the timing belt, turned out to be the kevlar timing belt making the noise. The noise sounded like the belt was too tight but when swapped to a rubber gates belt it was fine. Just a head up for anyone else who runs into this!
orion4096
35
Jan 25, 2016 03:37 PM
ehall20
11
Feb 11, 2014 08:16 AM
MJ23FE
Jan 25, 2010 05:10 PM
