EVO 6 build, 2.4 Block / Evo 8 head
Hey there, I wanted to share this project with you guys to see opinions and maybe a little bit of results from your end. And since is rare to find an evo 6 with a 2.4 block, I thought it would be nice to share some pics and info here.
I'm building a 4G64 block with 4G63 head, here some pics:
Dual Valve Springs for the head
A few engine accesories to build
Water pump comparison from 4G64 and 4G63
Manley Pistons
Manley Pistons Size
4G64 crank
Head, valve side
Machine work 4G64 block
Head with custom cover to check
Holes for the 4G64 oil squirters
Measuring piston pins with Rods
Assembling piston with rods
Old Eagle Rods vs Manley TT Rods
Wiseco Pistons vs Manley Pistons
All set
Rings and Gaps for the Pistons
Clearance
Piston inside the 4G64 block
According to specs
All set
Clearance again
Block almost done
Machine work for block
Building
4G63 vs 4G64 oil pan
Valves
Grinding valves
Some tests to the head with out home made thing
Almost ready
Aaaaand done!
Besides this, the supporting mods are: JB PTE 6262 .63 ar, 272 kelford, fuel lines -6AN, AMS fuel rail, FIC 1650cc injectors, AMS VSR Intake Manifold, AEM V1, Sparktech Non CDI, Excedy Triple HD, Race Buschur IC, ETS UICP and LICP, AEM Meth Kit, 5bar Map Sensor
This is the latest picture before the build:
This is the latest one, sleeping... (with some 17x9 RPF1)
I will be on C16 + Meth, what numbers do you think it will get?
More updates coming soon...
Manley Pistons
Manley Pistons Size
4G64 crank
Head, valve side
All set
Clearance
According to specs
All set
Clearance again
Block almost done
Building
Valves
Grinding valves
Almost ready
Aaaaand done!
Last edited by evo6panama; Jul 26, 2013 at 02:56 PM. Reason: Added an Exedy Triple Plate
I love it,
Looks a lot like what I'm in the middle of. My 4g64 came from a 2003 outlander and I still need to get my hands on evo 8 cylinder head core.
What C/R did you go with for your Manley pistons? I'm undecided, but will probably go with 9:1 with a slight increase after installing freeze plugs and having my deck resurfaced.
Build looks great!
Build looks great!
I love it,
Build looks great!
Build looks great!
I took the block from a mitsu galant in a junk yard it was a twin cam one.
I'm using 9:1 because of the gas quality here and yes, I think it will increase if you have your deck resurfaced.
Everything is done and great, the car is tuned by Gadiel on 38+ Psi on a Jack trans and transfer, I had to change the rear differential.
I share with you this vid with a Shelby Cobra GT500 and me at 27 psi on VP C-16
Hopefully we will be on the track on april to share some results.
I will be posting more pictures and videos on my Racingram account: Gianfranco M
Did you have to notch your block to clear the turbo tuff rods? How's your oil pressure with the oil squirters?
Glad it's running, and your enjoying it! Can't wait to say the same.
spdracr83
Jan 22, 2016 07:58 PM
