New stock frame turbo options from Blouch
Old Mar 31, 2015, 08:53 AM
e_kobz's Avatar
It appears Blouch Performance Turbo is stepping up to the plate and offering various stock frame turbos for the Evo 8/9. This is great news as it seems a lot of us prefer to go this route as opposed to changing downpipes, wastegates, manifolds, etc. I couldn't find any specs other than price and estimated hp output, but this looks like it could be promising.
Here are the different turbo options being offered:
Mitsubishi Evolution 9 Blouch Dominator 1.0XT Stock Frame Turbo
- $1695.00
- Journal Bearing
- 470hp est.
Mitsubishi Evolution 9 Blouch Dominator 1.0XTR Stock Frame Turbo
- $2250.00
- Ball Bearing
- 470hp est.
Mitsubishi Evolution 9 Blouch Dominator 2.0XTR Stock Frame Turbo
- $2350.00
- Ball Bearing
- 570hp est.
Mitsubishi Evolution 9 Blouch Dominator 3.0XTR Stock Frame Turbo
- $2450.00
- Ball Bearing
- 600hp est.
Old Mar 31, 2015, 09:33 AM
kaj
kaj's Avatar
i can't wait to see the difference in spool and power between the BB 1.0 and 2.0. i am thinking one of these will be my next turbo.
Old Mar 31, 2015, 09:36 AM
e_kobz's Avatar
Seeing as Blouch was behind the CBRD series turbos my guess will be that the 1.0 will be similar to a BBK Full, the 2.0 will be like a BBK-B, and the 3.0 will be like the BBK-C. That's my guess.
Old Mar 31, 2015, 10:18 AM
Jmills's Avatar
I'm also looking forward to seeing what these options are!
Old Mar 31, 2015, 10:25 AM
e_kobz's Avatar
I'm curious what kind of WGA is going to be offered as well as if they're offering anti-surge covers
Old Mar 31, 2015, 10:29 AM
Lazyfong's Avatar
"There is also a ported turbine option for an added 150.00, and an upgraded actuator for 135.00 if you would like.
There is a 6 month or 6,000mile warranty on the turbo through Blouch."
Old Mar 31, 2015, 10:30 AM
kaj
kaj's Avatar
links?
Old Mar 31, 2015, 11:30 AM
NoReason's Avatar
I've got the Blouch Dominator 2.0XTR in the mail on it's way here now. Can't wait to get it on the new build.
Compressor specs
57mm inducer
76mm exducer
Flow is 56-57lbs per min
Turbine wheel
11 blade High Flow 62mm turbine wheel
Ball bearing CHRA
Call them for more information. They do not have their website updated yet.
Old Mar 31, 2015, 12:36 PM
nemsin's Avatar
Do you know if/how the new "Dom" XTR turbos are different than the old Blouch 760-XTR?
There is precious little info on these so far.
Old Mar 31, 2015, 12:52 PM
NoReason's Avatar
I don't have any more info on this yet. I just spoke with them on the phone because they were looking at my trashed BBK and it couldn't be rebuilt. I wanted a comparable install like the BBK and they suggested their new turbo. I'll be getting it in about 3 weeks since I live overseas, it's got a long ways to go. Hopefully someone will have some pictures up by then. I'm pretty HYPED.
Old Mar 31, 2015, 01:15 PM
mrfred's Avatar
Compressor specs
57mm inducer
76mm exducer
Turbine wheel
Ball bearing CHRA
Those numbers are pretty close to the BBK-3B. The compressor inducer is 57 mm, and I didn't bother to measure the exducer. The turbine (11 blade) inducer/exducer are 63.5 mm and 54.5 mm, respectively.
Old Mar 31, 2015, 02:42 PM
R. Mutt's Avatar
All the info (thus far) is on page 6 of this thread just a few posts down:
https://www.evolutionm.net/forums/ev...ts-next-6.html
Originally Posted by maperformance
Ask and you shall receive!!!
For the Evo 8/9 Turbochargers here are the flow rates and HP Rating (Crank HP on Pump Gas).
Dom 1.0XT and 1.0XTR flow 47-48lbs per min
Inducer Wheel Size: 62.5mm
Exducer Wheel Size: 54.3mm
HP Rating: 480CHP
Dom 2.0XTR flows 56-57lbs per min
HP Rating: 570CHP
Dom 3.0XTR flows 64-65 lbs per min
Inducer Wheel Size: 67mm
Exducer Wheel Size: 60mm
HP Rating: 650CHP
For the Evo 10 Turbochargers here are the flow rates and HP Rating (Crank HP on Pump Gas).
Dom 1.0XT and XTR flow 47-48lbs per min
HP Rating: 480CHP
Dom 2.0XT and XTR flow 56-57lbs per min
HP Rating: 570CHP
Dom 3.0XTR flows 65-66lbs per min
HP Rating: 660CHP
We are absolutely ecstatic to carry the Blouch brand here at MAP and help them get these turbos out into your hands!
Old Apr 1, 2015, 07:11 AM
CBRD's Avatar
Yes- the stuff is very similar (if not the same) as what we were offering
Cheers
cb
Old Apr 1, 2015, 07:24 AM
kaj
kaj's Avatar
Cheers
cb
which is a good thing, IMO.
Old Apr 1, 2015, 07:25 AM
CBRD's Avatar
yes it is!
no problem
cb
Quick Reply: New stock frame turbo options from Blouch
