Take a journey into my Tranny - let's see what we find
#46
So, you didn't really find the cause of the weird fluid, or freeway. And you found some worn synchros. Hmm.
If the fluid is still weird with this fresh build, I would take the tcase apart and make sure the front diff is in good shape.
Your whine on the freeway could be tcase or rear diff if it doesn't go away.
#47
**Input Shaft Parts**
Evo 8 3rd gear
3rd gear Syncho set
3rd synchro spring
3rd & 4th gear slider
4th gear Synchro
4th gear syncro spring
**Output Shaft Parts**
5th gear needle bearing
Evo 9 2nd gear
2nd synchro spring
Output Shaft Bearing (clutch side)
Output Shaft Bearing (end side)
**Center Diff Parts**
Center Diff bearing (clutch side)
Center bearing (End side)
**Misc parts**
Clutch Throw out bearing
Evo 8 3rd gear
3rd gear Syncho set
3rd synchro spring
4th gear Synchro
Evo 9 2nd gear
2nd synchro spring
**Misc parts**
#48
Agreed, hoping the diff bearings I replaced will make a difference in high speed whine.
No idea where that color fluid was coming from, I'll run mt90 for the next 2k miles and probably change fluids 3-4 times to see how is going.
E46byeRAhi
09+ Ralliart Show and Shine
17
Dec 12, 2011 08:40 AM
ealt
Jul 31, 2010 10:26 AM
DC2toEVO8
Aug 11, 2009 08:56 PM
Joeekrub
Nov 21, 2006 05:42 PM
