do you have to remove to subframe to get transfer case out?
Old Feb 27, 2006, 01:54 PM
theblue's Avatar
I'm swapping out my transfer case and I'm about to drop the subframe.
I have the transfer case free but there is no way to get it to out... just can't move it around in any way that it will slide out.
IF I was to pull the transmission (which I have no need to do) - then it would probably come out easily.
So it looks like when I get back to work in the morning, I'll be dropping the subframe to get it out.
so if anybody has other advice then please let me know to save me from dropping the subframe if I can avoid it... thanks.
Aaron
p.s. dropping the subframe will = another aligment
Old Feb 27, 2006, 02:10 PM
theblue's Avatar
repost... looks like the subframe is coming out.
https://www.evolutionm.net/forums/sh...emove+transfer
Old Jul 22, 2008, 08:46 PM
keeler's Avatar
I know I'm bumping an old post but for reference you do not have to remove the subframe, if you remove it from the front of the motor. Just wiggle it out. We've pulled it this way over 4 times. On seperate Evo VIII's.
Old Jul 23, 2008, 11:19 AM
justboosted02's Avatar
easiest way is to remove the rear engine mount bolt and the crossmember mount, then jack the engine so it leans back (intake manifold towards firewall), then the TC will literally fall out
Old Jul 28, 2008, 01:04 PM
theblue's Avatar
where were you guys 2 years ago when I needed help
ProPilot04
55
May 13, 2018 09:42 AM
OX
Dec 30, 2016 05:52 PM
mitsuatb
15
Aug 10, 2016 06:37 AM
dangina
Sep 12, 2014 08:26 PM
ball7068
Aug 5, 2012 08:19 PM
Quick Reply: do you have to remove to subframe to get transfer case out?
