COP setup wiring (Denso 90919-02240, Yaris/Echo Schematics)
Old Oct 26, 2012, 10:11 AM
domyz's Avatar
Originally Posted by OsideEVO
I bought 4 coil w pig tail for $45 and $30 worth of supplies from spoolinup. Great cheap mod.
Great price you beat me! Good luck
Old Nov 8, 2012, 12:55 PM
OsideEVO's Avatar
Can anyone tell me where i can find a connector diagram for denso 90919-a2001 (2005-10 camrey and corolla)
Old Nov 8, 2012, 04:54 PM
OsideEVO's Avatar
The harness is the same color... asking because my carthe wont startget w thea COP
Old Nov 24, 2016, 10:55 PM
gIGoN's Avatar
Hey guys,
I know this is an old topic but i need to inquire a few things. What happens to the stock ignitor? Do i remove it or do i still need it. This diagram, does it apply to 2G /EVO III as well?
Old Nov 25, 2016, 04:19 AM
domyz's Avatar
You will be able to remove the 2 stock coils setup (and you should, because there won't be anymore space for them anyway)
This diagram applies to pretty much every car that has a 2 coil wasted spark setup, but for wire colors I'm not positive they will be the same with your older ECU. Try to source the coil wiring schematics on your specific application, and transpose the colors on my diagram.
Old Aug 13, 2019, 07:50 AM
Tommyfacekicker's Avatar
did your coils sit a little high off of the plug? doesn't fit snug when the mounting plate is added? I test fitted my 9 with scion xa coils and they sit snug when they're below where the mounting plate would be mounted.
Old Aug 13, 2019, 08:44 AM
domyz's Avatar
I wasn't using any custom mounting plate... just the yaris coils and the stock cover
(I sold the car 2 years ago)
Old Aug 14, 2019, 11:55 AM
thanks for the reply. did they move around ? mines are kind of wobbly if i just set them in place like that.
Old Aug 14, 2019, 01:34 PM
Terror Rising's Avatar
I ran mine for years of auto-x under the stock cover with no plate and no problems. Then I chased intermittent spark issues for over a year which was only solved by buying new extended springs and mounting the coils on the plate. I thought it was coils, coil springs, plugs, and the COP wiring and kept chasing my tail (I don't really have a tail) until the only thing I could do was buy the plate and get rid of my spark plug cover. The issue has not resurfaced since so that's how they're going to stay.
Old Aug 14, 2019, 01:47 PM
domyz's Avatar
I didn't have any issues for 4 years (about 60k miles). They can still bolt on the valve cover with that stock screw right ? If wiring is tight and welded good, I think you're fine. But of course getting a good plate might be a good idea if you do track/auto-x or quarter mile. I didn't do any of that with mine.
Tommyfacekicker (Aug 14, 2019)
Old Aug 14, 2019, 03:06 PM
thanks. I will try to bolt them onto the v/c and cover it with the original cover. if all else fails, i'll make a plate and stretch the coils.
Old Apr 4, 2020, 03:17 PM
knox839's Avatar
Better stick with coils that has known OEM-like dwell time.
If you don't know this parameter for 350z ones they could misfire,
or burn if their dwell time specification is longer, or shorter.
Also, physically they look too big to fit under the stock cover (not a big problem)
You can get 4 yaris coils from junkyard for under 100$ with pigtails.
what dwell times did you use? Because I read somewhere because of wasted spark you can not run yaris coils peak dwell time (2.4ms)
Old Jun 27, 2022, 08:04 AM
Wulfen's Avatar
"Yes they are saturated by about 2.4ms @14V but they dont like to run that high for very long - especially if run wasted spark they will overheat quickly. So this dwell table runs them 2.1ms most of the time then just bumps it up near the peak torque area where it may be needed." -This is from LinkECU forums
https://forums.linkecu.com/topic/951...o-099700-2550/
Greg Sharpe
36
Nov 15, 2020 11:19 AM
Eisen7
11
Feb 28, 2020 12:42 PM
YFZracer32
Oct 25, 2015 07:14 PM
joedr
24
Dec 31, 2008 07:11 AM
JohnBradley
May 28, 2008 11:23 AM
Quick Reply: COP setup wiring (Denso 90919-02240, Yaris/Echo Schematics)
