Bilstein PSS9 NOT what I expected. .
Hey guys, first of all yes, I did search, I actually searched for MONTHS until I decided to purchase the PSS9... well finally got them installed in my car, lowered about 1cm all around, took the car for a spin and the car does not handle as it used to, even in the hardest setting (1) it feels "unsafe" if you know what I mean... I also installed a set of new tires, falken azenis stock size, coming from the OEM potenzas, those tires might have something to do with the loss of performance...
Anyways, if anybody can help me out, what can I do to make the car ride better (like it used to on stock KYB's) besides selling the PSS9's??
Are the springs the same front and rear? because they looked the same so I just installed them randomly. . . I really liked the way the car handled before, only reason I changed suspension was because 2 struts were blown.
I find it hard to believe that such an expensive suspension (pss9) can not perform like the stock KYB's I must admit that the ride is nicer for city driving in the soft settings, but I miss the security the stock suspension gave me in spirited drives... thanks for any help I can get
Get an alignment. I have the PSS9s and they handle a lot better than stock, even on the softest settings (9) I notice a difference.
spring rates are different front and rear for those arent they? I dont think you can really tell just by looking at them. You might have swapped the wrong springs into one or two of them and that could be causing your issue. Also, to get the full benefit of coilovers, you need to get it corner balanced.
It's a JDM RS, Potenzas came stock (amazing tire, only lasted 10k miles ) I got the car aligned but is that corner balanced thing? If I remember correctly all springs had the same number, will have to check tomorrow and get back to you guys, thanks a lot for your help.
Show286, the ride has improved overall, but not in an aggressive way, meaning I can not takes turns as fast as I could before (anyone else think it could be the falkens??)
Since some of you suggested to get the car corner balanced, can anyone tell me how to get that done? thanks
"unsafe", no i don't know what you mean. Please enlighten us.
I've been riding on PSS9's for about 9 months now. Aside from some front end clunking which was fixed, I have nothing but good things to say about them. Yeah, they are on the softer, comfortable side of coilovers, with less adjustability compared to a v3, but for the NYC daily driver I am satisfied.
When I started i kept them in the softer range, 6-8, but as I increased the stiffness, I actually enjoyed the way the car felt more. I now drive on setting 2 on all 4 corners.
When I say "unsafe" I mean I do not feel as comfortable as before taking fast turns, the car actually sinks into the corner and the tail feels like is comming loose, that's what I mean by "unsafe"
Did you change ride height with your bilsteins? I lowered the car a bit, maybe that is affecting things, only thing I know is the car felt like a go-kart before, not anymore with the PSS9's
I never got installation instructions with mine, is there anything important in there I need to know? thanks
I know now that they are missplaced, but does anybody know which springs go at the front and wich at the rear?
Ok I went out and looked, one spring on the rear reads E4 FD1 Y497 A00 and the other rear reads E4 FD1 Y583 A00... same thing on the front springs, one reads E4 FD1 Y497 A00 and the other E4 FD1 Y583 A00.
