EVO X MR. Strange dip in dyno
Old Sep 11, 2014, 02:28 PM
Shirish Agarwal's Avatar
I have a 2008 Evo xMR. I bought it recently and was told that its stock. However,after looking at dyno it looks like its tuned.
There is a strange dip in dyno and was wondering if anybody could help with this.????
Also, people tell me they hear some strange flutter when i let go off gas after WOT.
Looking for some advice.
Last edited by Shirish Agarwal; Sep 11, 2014 at 04:48 PM. Reason: Adding Dyno Chart
Old Sep 11, 2014, 02:31 PM
Ralliart09er's Avatar
Charts would help. What were your numbers on the dyno? What do you mean dip? Whats the dip showing on? Help us help you. Your blow off valve is making the noise?
Old Sep 11, 2014, 02:46 PM
Added dyno chart.. Thanks for pointing it out Both hp and torque are dipping. I dont have a BOV. I have a recirculating valve. Its either wastegate flutter or recirculative valve causing turbo flutter (not sure what and need advice as to what to check and how)
Old Sep 11, 2014, 05:48 PM
JohnBradley's Avatar
No boost numbers though?
Old Sep 11, 2014, 08:04 PM
acidtonic's Avatar
Interesting torque spike at the end.... that looks scary to me. Could also just be knocking and lots of timing getting pulled but I'd definitely get a new tune or at least a second opinion if I were you.
Good luck
Old Sep 11, 2014, 08:09 PM
Bhsj13's Avatar
clutch? maybe not...
Old Sep 11, 2014, 08:11 PM
It usually runs max 22-24 psi max boost. Thanks guys.. will surely try to get it tuned soon.
Clutch doesnt slip or anything. So I doubt it.. and its MR. So no lag also I believe..
Old Sep 13, 2014, 07:46 PM
surferjeff's Avatar
I'd definitely get a retune you don't know what's in there would be a good idea to know what is in there
Old Sep 14, 2014, 08:05 AM
bellacotim's Avatar
Torque dip could be due to clutch slip, which was in my MR was at its worst around 6K RPM before the ECU SST related tables we adjusted. Try logging a street pull 2.5K-7K RPM and you see a corresponding torque "blip" in VD at around the same RPM range as the torque dip above.
Old Sep 18, 2014, 07:46 PM
cool.. will log using vd soon.. hope its not clutch slip.. this stuff is too expensive..
Old Sep 19, 2014, 05:04 AM
Locke's Avatar
Are your getting any CELs? If it is not a mechanical slip, it may be Torque Compensation. Definitely need a bit more info...data log would be great. There are absolutely no bolt on mods?
Old Sep 22, 2014, 08:30 PM
No CEL at all. I bought it stock. Took it shop for servicing and all but was never told it had bolt on's. They say it is tuned for sure (amazing how tune can get 304 wheel hp).
What kind of data should I get?
Old Sep 23, 2014, 04:01 PM
ikt
ikt's Avatar
CEL could be disabled
And a tune could get that w/a boost controller but idk how safe of a tune...
is it a stock boost controller?
Old Sep 23, 2014, 06:02 PM
[QUOTE=Shirish Agarwal;11306546
What kind of data should I get?[/QUOTE]
Boost pressure thru the whole power curve.
Shanedixon1987
12
Jan 7, 2016 10:04 AM
strang3majik
For Sale - Cars For Sale
Oct 7, 2015 03:20 PM
kyoo
17
Oct 11, 2010 06:59 PM
PERRIN_Jeff
34
Jan 27, 2009 05:43 PM
sasquatch
Jun 5, 2007 03:55 PM
Quick Reply: EVO X MR. Strange dip in dyno
