EnglishRacing Drag X 1199whp 8385 Gen 2 59psi
Old Dec 6, 2016, 01:23 PM
JohnBradley's Avatar
Originally Posted by Fast_Freddie
What about Honda EP3 civic electric power steering Aaron?
Forgot about those ones. The MR-S only because I have seen it done
Old Dec 10, 2016, 10:11 AM
h24
h24's Avatar
Yeah, the MR2 electric p/s pump is the way to go. Just find a mounting location and do the plumbing. They do make a little noise, and not quite as smooth as a conventional p/s pump, but you gotta give a little. The electric rack would be a nightmare to get working I would assume.
Old Dec 13, 2016, 01:05 PM
For a daily I could see noise being an issue, but a hood exit exhaust car with belt driven mechanical fuel pump...that might be the quietest part of the car
Old Dec 15, 2016, 05:31 PM
h24
h24's Avatar
^ Yeah, its really not thaaaat noisey. For that type of car, hell yeah, it would be butter. Only time you hear it is when you are idling and turning. Once the wheels start rolling its no big deal. That build is super rad you guys got going there! Excellent job English, inspiring!!
Old Dec 17, 2016, 05:19 PM
theblackbeast11's Avatar
are you guys running the off the self beehive gsc valve springs If so Did you guys have to do anything special to be able to run that kind of boost? As i see they are only rated at like 40psi so just wanted to know what you guys are doing to not float valves ?
Old Dec 21, 2016, 03:47 AM
The_X_Effect's Avatar
Talk to rickerman. He relocated his power steering pump to the trunk and made it electric
Old Dec 21, 2016, 08:15 AM
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
Considering what GSC rates those springs at, I would say ER is running something custom.
Old Jan 13, 2017, 11:04 AM
We are running custom stuff right now and then shimming them to get the rates we need. The car has been as high as 64psi and 10,400rpm so the test is working
Old Jan 16, 2017, 09:40 AM
fhyk.'s Avatar
64psi.
10,400rpm.
Wow...
Old Jan 18, 2017, 06:56 AM
spoolin turbo's Avatar
Great work. Motor is holding together amazing.
Old Jan 20, 2017, 09:47 AM
GTijoejoe's Avatar
What. The. Hell.
Jeeez great things
Old Feb 6, 2017, 08:55 AM
cerealkeller's Avatar
My God! It's unbelievable the performance you squeezed out of that build. Amazing the power you can get with a big frackin turbo and the right fuel. These results are really interesting. I've been planning my build, but it looks like the heads clearly don't need any porting and the stock crank can hold obscene power safely.
Old Feb 6, 2017, 05:22 PM
Quite literally the exact opposite. The 4b11 head takes a lot of work to make big numbers.
Old Feb 6, 2017, 09:27 PM
RazorLab's Avatar
Received 1,038 Likes on 760 Posts
Can you elaborate? This car is making 1200whp with a stock port head...
I keep seeing you say this but there are a plethora of 700whp+ 4b11's with non-ported heads.
Old Feb 9, 2017, 05:45 PM
Evo2372's Avatar
What a friggen monster.... I love that you kept standard porting on the heads. Goes to show it was done right from the start. Plus what can be obtained in the right hands, as for that 6" cooler WOW>
If I ever win the lotto I will ask you guys to build me a monster X to run in Oz.
Keep up the great work.
Quick Reply: EnglishRacing Drag X 1199whp 8385 Gen 2 59psi
