Do I need tuning after small downgrade?
I'm going to replace my ETS Open dump downpipe and Race catless test pipe with ETS recirculated downpipe and ETS high flow Cat pipe. Do I need to do tuning or nothing bad is going to happen if I don't?
Because I can replace it in any muffler shop where if I need to tune it I need to go to special one.
That's a big change in exhaust flow. Will be ok to cruise around on, but will likely be off running WOT, I would recommend a tune..
Thank you. I went to local tuning place and did a dyno run to see what I have now. They said that turning is not really required after the downgrade. I'll do another dyno afterwards. They said that most likely I'm not going to see HP decrease, only AFR will be different
EvilDylan
Mar 24, 2005 08:59 PM
