Rough Idle 12 Evo X
Old Apr 17, 2013, 07:33 PM
EvoAirRick's Avatar
Rough Idle 12 Evo X
So the other day I noticed my car to idle rough when i got to work. I checked fuel pump relay it was popped out a little and that solved the problem, then I noticed it idle rough 1 to 3 times at a stop light, I have already replaced the relays with the SSP Kit, and checked my FP line and that is fine as well. What could it be, searched around the forums could not fine anything about it.
Old Apr 17, 2013, 07:48 PM
theoutfitplayer's Avatar
Could you explain rough idle?
My car idled weird when i didn't have my heat shield on. The heat from the radiator would cause it to idle awkwardly. Not sure if that helps.
Old Apr 17, 2013, 08:17 PM
warzywko's Avatar
sounds like a vacuum leak, check all your couplings and hoses
Old Apr 18, 2013, 01:04 AM
EvoAirRick's Avatar
Also car is completely stock, well when I'm at a stop the whole car shakes then stops then back to normal sometimes I doesn't do it
Posted from Evolutionm.net App for Android
Old Apr 25, 2013, 05:50 AM
Does the rpm gauge move up or down at all when the shaking is happening?
Not sure really what it could be if it is stock. Seems very odd to me. Have you called the Mitsubishi dealer yet and explained the problem to them?
How many miles do you have on the car?
FL3JM
Feb 26, 2017 10:30 AM
Domengg Domino
Dec 1, 2016 12:07 PM
ghozt
Sep 14, 2016 07:04 AM
OPENA(671)
Sep 5, 2013 09:54 PM
arievox
Jun 20, 2013 02:46 PM
Quick Reply: Rough Idle 12 Evo X
