Cruise control malfunction
Hey guys, just picked up my 2014 GSR mid December and have been having an issue off and on with cruise control not setting initially. Every couple days I get up to speed, hit "Set Cruise Control" 3-4 times before anything happens. Anyone else experience this?
Not necessarily a bad bulb. What he is referring to is, if by chance, you have a short between the rear running lights and the brake light, the car thinks you are pressing on the brake pedal when you're not, and disengages the cruise control.
Try this: go drive with your lights OFF and try to use cruise control. Then turn your lights ON and repeat the procedure. If they work with lights OFF but not ON, this is probably your issue. If you turn your lights on and you are able to engage cruise control, this is not your issue.
Bosshog
Mar 18, 2013 12:13 PM
