How to: Oil and filter change on the EVO X
I've used variants of both brands back when I was a mechanical engineer designing equipment and for 20+ years of racing with outstanding results. Synthetic lubricants are all so damn good its hard to find one that's remarkably different from another. Every time I open up an old race motor that had synthetic oil all of the bearing and ring surface look so good its unreal (compared to engines that have used dino based oils).
Sometimes on some beater cars I'll use dino oil, but only Castrol GTX (it always obliterates other dino oils in testing).
OK, I could go on and on about oils and testing, but that wasn't the intent of this thread. Just a quick "this is the EVO X oil change" how to.
Thanks for doing this writeup! Wasn't trying to find fault with your how to, just trying to warn others based on what I've heard about overfilling leading to aeration/foam. You seem to have much more experience with it than I do, so I'm definitely not trying to argue. I'm probably just crazy about being exact with my oil levels
Castrol or Mobile 1 ... I don't care. I usually buy what's on sale. They are both STELLAR synthetic lubricants.
for those of us that dont have lifts where do you suggest jacking up the car? One jack in the middle of the front somewhere or two jack stands in the front or some rhino ramps? Since Ill have to jack the car up is the slope going to affect oil drain? Should I drop it back down as the oil is draining then lift back up once im done?
Do you replace the crushwasher or do anything with that?
Thanks a lot for the write up. As you can tell Ive never changed oil on a car and my X is coming due for its first change. Ive been looking up how to change oil in general but this definitely helped a lot being specific to my car.
I posted this thread.
https://www.evolutionm.net/forums/ev...floorjack.html
WM
Is there any blank plugs near the oil filter like on the VIII/IX just if someone wanted to run an oil pressure gauge or something?? I haven't taken a look for one yet I forgot to when I changed my oil.... duh! lol
According to the service manual, the oil change should be 5.64 qts. I used 5, ran it, shutdown and found it was almost 1qt low. THEN AGAIN, I actually drain the oil from the oil cooler, something most people don't bother with...
