Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Front Fender Tab relocation
Old May 24, 2014, 06:10 PM
JSpeC21's Avatar
Is there a write up around here? I'm running 18x10.5 +22 all fenders rolled, but my front keeps rubbing. And the culprit is that bumper tab where it bolts to fender. Please help!!! I'm trying to avoid using bumper quick release.
Old May 24, 2014, 06:11 PM
JSpeC21's Avatar
265/35/18 tires too
Old May 25, 2014, 08:48 AM
gsrboi80's Avatar
Maybe raise the car up or buy wheels that actually fit the car. Seems most logical to me
Old May 25, 2014, 10:48 AM
JSpeC21's Avatar
yea thanks...... i'll be sure to take that into consideration.
Old May 25, 2014, 01:27 PM
gsrboi80's Avatar
That's right 90% of current Evo owners just want to be "mad tyte slammed herrfrush yo"
Logics go right down the damn toilet. **** it just let it rub till it completely grinds the bolt away, or rips the fender and bumper clean off the car. Then just use zip ties
GL.
Old May 29, 2014, 11:34 AM
ikt
ikt's Avatar
you can remove the large 10mm bolt and use a screw with big threads and a flat head. Match the diameter. That 10mm bolt threads into a plastic body clip retainer, so, any flat headed faster will also fit.
If you want to remove the tab completely, that's a doable thing but you'd need some plastic fabbing skills....
Old May 29, 2014, 12:41 PM
4bangn's Avatar
GL.
90%????...god I hope not
Old May 29, 2014, 12:48 PM
powerdriver's Avatar
You could probably shave that tab off, headlight doesn't need another bolt holding it down, on top of that use the quick release method to put the bumper back on.
http://www.aliexpress.com/item/Passw...FbRxMgodRgEAYQ
Old Sep 16, 2016, 11:55 PM
austin1102's Avatar
raise the car alittle im running work emotion 11ft-r 18x10.5 with a 295/30/18
joeBPUsupra
Aug 2, 2017 11:15 AM
wiser1000
Jun 22, 2017 11:56 AM
119Evo
May 4, 2017 09:11 PM
Loxias
Mar 3, 2017 05:30 AM
ChicagoEvo9
May 20, 2016 07:18 AM
Quick Reply: Front Fender Tab relocation
