Is 350whp attainable?
Old Jan 21, 2010, 12:05 PM
MEVOLV3's Avatar
'03 E8
Mods:
-stock IX turbo
-Megan tubular 02 housing
-3 in TBE; DP/SP/Apex'i WSII muffler
-Perrin complete turbo intake
-Hallman MBC
-Muse LICP
-IX DV
-Walbro 255
Coming soon...
-TTP Mustang dyno tune on 93 octane
Really want to stick to a "Stock turbo/full bolt-on status," but will entertain the idea of Kelford or Cosworth 272's if needed...(No meth or water injection though)
Thanks for any input!
Old Jan 21, 2010, 12:08 PM
CoachG's Avatar
With cams, a good tune/tuner, and on a Dynojet you should be in the right neighborhood.
Good luck,
Coach
Old Jan 21, 2010, 12:09 PM
Protostar1's Avatar
Depends big time on the dyno, but I hit 371whp on AMSs dyno with our only difference being an IC and piping (which I believe I got about 20whp with a perrin filter).
Old Jan 21, 2010, 12:13 PM
chaotichoax's Avatar
on a "typical" mustang dyno...no, not on pump gas (excluding e-85)
a typical evo 9 can make 330-350 whp on a dynojet on 93 octane
a typical evo 8 needs cams to match a stock cammed 9's numbers on 93 octane
Old Jan 21, 2010, 01:00 PM
oneofakindtrini's Avatar
Depending on your tuner that should be attainable.. Look into some cams though. Perhaps some kelford 272's or something such as that.
Old Jan 21, 2010, 01:04 PM
borievoinitialD's Avatar
i am at 360 currently on a ttp tune on his md dyno...
u will need cams in my opinion to reach the goal
I have pretty much everything u have plus hks 272's and a DLI
Old Jan 21, 2010, 01:06 PM
MEVOLV3's Avatar
Will the valvetrain need upgrading if I run either of those cams?
Old Jan 21, 2010, 01:15 PM
i have no idea about kelford or cozzies, but you dont for the hks's...that kinda played into my decision as I wanted around 345-370 with minimal lag
Old Jan 21, 2010, 01:21 PM
evo unknown's Avatar
Good luck,
Coach
^^Good advice
You probably can obtain that number with turning the boost up pretty high, 24-25 psi, or you could install cams, spring, and retainers and definitely get those numbers while keeping the boost lower.
Old Jan 21, 2010, 01:30 PM
McLaren F1 2003's Avatar
this is it, exactly
you dont need them , but why not get them if youre already going to be in there. they are nice insurance
Old Jan 21, 2010, 01:56 PM
MitsuJDM's Avatar
You'll need atleast a set of cams and be somewhere around 310-330whp. 350whp on a mustang is real good power with bolt-ons.
Old Jan 21, 2010, 02:16 PM
mifesto's Avatar
You'll get roughly 340's with a conservative tune , I'm estimating. Maybe 320-330 if u didn't get the cams. Fmic will also help to hit that 350 reliably while keeping the tune conservative...
Old Jan 21, 2010, 04:04 PM
A perfect example of this would be a about 2weeks ago, E-Spec was tuning a GG evo9 and with less boost the car made more power because there was too much restriction from the stock intercooler and a cat. A larger FMIC will help you out on your way up to 350+AWHP, as well as cams.
Old Jan 21, 2010, 05:20 PM
EvoJoeIX's Avatar
if you get a TTP tune, he will manipulate your numbers so you can have as much power as you want. haha
Old Jan 21, 2010, 05:41 PM
MEVOLV3's Avatar
awesome feedback guys! keep it coming
Quick Reply: Is 350whp attainable?
