most important gauges
IMO Oil pressure, AFR, Oil temp, and boost are probably all you need. Water temp, EGT, and Volts would also be nice. If your running E-85 a gasoline content analyzer is also useful.
Agree with that.
For me I am running Oil Temp, Oil Pressure, and Fuel Pressure, and an AEM Net Gauge which shows me all sorts of stuff, but I mostly run it in AFR. Fuel pressure gague is going away, because I dont need it.
THe only two gauges that you can really use while driving are Oil Temp and AFR, you will not be able to notice a drop in oil pressure during a 3rd gear pull and shut it down before damage. But again most of the time the gauges are not going to help unless they are wired into your computer and can trigger a failsafe.
boost,a/f,and oil pressure.i think oil pressure is your most important but that just me ,but when i driving its hard to look at your gauges and concentrate on driving at the same time
Tracer
23
Apr 7, 2007 12:48 AM
v8killer
63
Feb 24, 2005 08:45 AM
ZeroFrost
12
Jun 14, 2004 02:17 AM
