What gauge is next most important???
Old Jun 13, 2004 | 12:02 PM
ZeroFrost's Avatar
Ok i got a Greddy Turbo Timer and a Boost gauge, what gauge is next most important to get?
Old Jun 13, 2004 | 12:16 PM
platinumspecv's Avatar
Well if you are going to mod your car .. change a/f ratio's, bolt ons - get a Exhaust temperature gauge. It's a nice precise way to tell if your motor is running rich or lean. You can search for a "Pryometer Gauage" and you'll find one
Krunal
Old Jun 13, 2004 | 12:19 PM
ZeroFrost's Avatar
well i got the Megan Racing 3" Turboback exhaust and a Intake. So what now?
Old Jun 13, 2004 | 12:22 PM
BSREVOLUTION's Avatar
Egt
Old Jun 13, 2004 | 12:44 PM
ZeroFrost's Avatar
whats EGT i forget?
Old Jun 13, 2004 | 01:07 PM
propellerhead's Avatar
Personally I went with a Wide Band O2 gauge. Granted, it's alot more expensive but it's a dead-on measure of whether your car is running rich or lean.
Old Jun 13, 2004 | 01:48 PM
ZeroFrost's Avatar
ok so a boost gauge and a air/fuel ratio gauge? or Boost gauge and something else?
Old Jun 13, 2004 | 09:50 PM
paulblackgsx's Avatar
My suggestion would be EGT, then oil pressure, and fuel pressure.
A/F gauge although a good safety net won't tell you much more than an EGT gauge since a non-wide band O2 sensor isn't very accurate. If your willing to spend the money, wideband O2 will give you a pretty accurate reading of A/F and is a good tuning tool.
Old Jun 13, 2004 | 10:09 PM
bolsen's Avatar
narrow bands are only good for civics and christmas trees.
Get an oil temp gauge.
The egt will tell you if you are running rich / lean.
But since you are on stock programming, I'd say get oil temp. That will tell you when you can beat on your car, since the coolant warms way before the oil does. While you don't even really need a gauge, if you really want one, get one that you can actually use.
Old Jun 13, 2004 | 11:12 PM
Bexa20's Avatar
Correct me if I'm wrong. On EGT gauge if temp is higher it means I'm running lean, if temp is lower it means I'm running rich, or the other way around ?????
Old Jun 14, 2004 | 12:33 AM
areet's Avatar
It could go both ways in extreme since unburned gas would ignite in the exaust system. It's a tool to tell you when you're about to melt your engine.
Old Jun 14, 2004 | 02:11 AM
EVOVII_SWE's Avatar
If you have the EGT probe in one of the runners, maybe 2-3 inches from the head, at what temperature are things starting to get dangerous? Does it make any difference that I have forged pistons?
Old Jun 14, 2004 | 02:17 AM
Boni's Avatar
Greddy EGT or Wide Band 02 w/ Air/Fuel guage.
hktrigguy
Jun 16, 2017 05:23 PM
winzo
19
Apr 24, 2013 09:47 PM
xpehbam
Sep 11, 2008 10:32 AM
Tracer
23
Apr 7, 2007 12:48 AM
Turbo-Evo2346
Mar 26, 2006 01:41 PM
