Lancer Oz 2006 M/T Turbo
#31
yeah, that could be it...I would try a different sensor. It's unsettling seeing knock, and not being sure if it's there or not...usually knock sensors are pretty good at detecting what's knock and what isn't...
when the knock is detected, does the ECU pull timing on its own?
#33
Finally found a LSD for the 02-06 lancer here in north america! Can't wait to try my new Kaaz 1.5 Way Super Q LSD part number DBM2050 clutch type lsd
#37
Hey, how do you like the LSD in the Lancer? I am searching for one to put in an OZ Rally for SCCA Rallycross, and came across your posts. Did you do the install yourself? Any pointers with regards to setting the backlash, etc? Thanks in advance.
#38
The LSD is day any night honnestly for the track! Installed everything by myself but i didnt touch the clutches inside that were set at 100% lock...i recommend asking for 80% lock when you buy it or switch the clutches yourself to make it 80% lock...the 100% lock is REALLY agressive and u hear it shatter everytime u turn at low speeds. Also make sure to measure the diff to case clearance and use the appropriate shim accordingly
#39
Another update on the build! I now use the AEM EMS Series 2 from an Evo 9 Part #30-6320 all you have to do is switch the pinout between the fuel pump and A/C clutch in the outputs of the EMS. Got it tuned by RD Turbo Productions, one of the best in town here in montreal and made 242whp/306wtrq peaking at 18 psi and stabilIzing at 15-16 psi
Mahmoud Evo (Mar 17, 2020)
#41
Im not sure about the MAF....i think u can run the stock MAF below 10 psi but dont quote me on that...as for the MAP it doesnt matter if you're running a regular map...you would need a 1-3 BAR map if you were to run a Speed Density ROM and your MAF would only be used for the IAT sensor in it.
Mahmoud Evo (Mar 27, 2020)
marcouxa1
Lancer Aftermarket Forced Induction Tech
28
Nov 5, 2023 05:28 PM
03Evoftw
Jan 8, 2014 03:28 PM
*02Lancer*
202
Jul 14, 2011 09:07 PM
brutus.nova
Oct 15, 2009 03:16 PM
jimib
98
Jul 15, 2009 03:28 PM
