Amp wiring digaram
Thats so awesome, thanks!!
How do you know all that? Put a new system in your car and had to find out the hard way?
Why so many power and grounds?
Whats a left/right line in? Kind of like a RCA cable but different?
No but i am about to start to build in my own evo x so i searched the forum and found this and the lancer and evo is almost the same inside so i check around in other forums to not only the evo x part. https://www.evolutionm.net/forums/ev...d-oem-amp.html
I made another post, but maybe someone here might know. I am attempting to hard wire in a Rockford Fosgate amp out of a 2010 Lancer into my 2015 Lancer (that did not come with the rockford option) I have the amp and both connectors with leads. I have the three red wires tapped into the 30Amp power wire that comes pre wired into the dash and ran it the rest of the way under the seat. The three black ground wires are grounded to the body. I ran wires from the connector by the back seat where the sub wires end to under the seat to the amp. And all thats left is the audio wires from the radio and the amp turn on wire. The problem is I cannot determine which wire is the amp turn on, if its the blue, or pink. And i believe the amp turn on wire isn't the standard 12 volts, from what i've read its believed to be 3. Has anybody done this installation before and if so what did you to do make it work? All I want the amp to do is power the subwoofer (factory subwoofer out of a 2013 lancer.) The radio can run the rest of the speakers like normal.
Thank you!
Thank you!
crabs_mcjones
May 29, 2016 11:41 AM
Migsubishi
May 11, 2016 05:28 AM
