EcuFlash: Rev Limit problem
Heres the situation:
Went to tune the car(Lancer DE 06)
Result were pretty good
But the Rev Limit was crazy
In neutral the car would rev up to the reflashed value(6800rpm)
But when doing the dyno run it would only rev up to stock value(6200)
Then in the final run when we let the car cold down it did rev to 6800rpm
How can i make it rev to 6800 constantly?
I'm going to install a cam in the near future thats why i want to rise it
Heres the dyno graph
Thanks for your help
ROM ID is 88250012
Stationary Rev Limit was the default value(7500)
And the i set the Rev Limit to 6800
I can show you logs where it didn't reached 6800rpm
And then suddenly in the last run it did
Unless the Def was wrong (i just copied it from the 88250013 that is around here)
I don't what could it be
bellacotim
Nov 27, 2013 03:30 PM
