catback straight pipe
i just had a 3 inch straight pipe welded and installed on my x. it revs somewhat smooth up to 6800rpm but my bottom end is non existant . I do notice that it pulls harder between 4-6ooo. theres a burschur airfilter as well(it sounds cool but i dont feel it make power). Is this performance expected with a straight pipe and no ecu tune? btw im new here and thanx for haveing me !
So let me get this straight you just got a 3" straight pipe from the cat all the way back with no muffler. If that is true had does that sound, I can see it sounding good at all. If you just got it done the computer still maybe adjusting. I know when I put on my cone filter I reset the ecu and it seemed to help alot.
backpressure gives you low end torque I believe. I had a cbr 929 that had a valve in the exhaust system that would open above a certain rpm, this came stock and it was i was told to leave it on and just put a slipon.
i believe this is true of N/A motors only. With turbo cars, the less piping connected to the exhaust side of the turbo is better... someone please correct me if i'm wrong.
yes its 3 inch from the cat back (mandrel bent tubes) No muffler at all. Its sounds like a evo now and its not that loud. No ecu problems yet or dash lightscoming on. does anyone know what type of performance i should expect from a ecu tune with this mod?
Wow if you get a chance i would love to hear what that sounds like. Can you post up a sound clip if you have time. I bet that was a pretty cheap mod at the local muffler shop. I tried to get a custom exhaust, but no one in san antonio has a mandrel pipe bending machine.
did u reset the ecu ? how long have u driven it? could take a 100 miles or so to learn them.
back pressure is actually kinda bad for the turbo, I agree, more flow out from the turbo is better.
you would think it would be loud but it sounds like a 9 with a turbo back exhaust system. but it does sound badass !! now that I have the factory reflash i do feel more power on the topend . as far as price ,it was cheap( $315 otd) and installed .
who reset the ecu for you? i have seen on some threads people talking about reseting the ecu. are you referring to unpluging your battery?
I think i remember reading about this before. Back pressure does not increase torque but rather exhaust escape velocity. I would agree with evox_sa in that you should probably try resetting your ecu. That might help.
