Definition Problems with ECUFlash
Old Sep 11, 2009 | 11:06 PM
Midnightkid's Avatar
First time ECUFlash user here naturally. I updated my ECUFlash with all the definitions from the master definition list. Dumped the master list into the rommetadata/lancer folder. When I open up ECUFlash, I select the 2001-2005 Mitsubishi 3rd Gen/EVO7-8 option (I don't see any lancer options or what not). ECUFlash reads my Rom no worries and brings up all the data. It loads up the Definition for an 03 OZ Rally with a manual transmission. One thing though, my Lancer is an 03 ES with an Auto Transmission. Any ideas? I've browsed through dozens of pages regarding ECUFlash and didn't get where I needed to go.
Old Sep 11, 2009 | 11:13 PM
link62's Avatar
hmmm im an 03 es and i havent had any problems and it even loaded the right def for me
Old Sep 11, 2009 | 11:15 PM
link62's Avatar
heres a pic of what mines looks like
Old Sep 12, 2009 | 12:32 AM
03lances's Avatar
Same here 03 es but im manual mine looks just like link62. Kinda confused on what your asking? All the data comes up and correct? Are you just worried because the rom info reads manual trans?
Old Sep 12, 2009 | 01:27 AM
Pretty much, my computer connects to the ECU like normal (Or what I think is normal), but when it pulls up the ROM, all the Parameters come up, except everything is blank. I can't edit nor look up anything. When I check the ROM info, it pretty much says it loaded the 03 OZ MT Definition. It's weird. EVOScan works perfectly fine.
I'll post up a screenshot in the morning
Old Sep 12, 2009 | 01:46 AM
03lances's Avatar
Ok I see what you mean now, strange...
Old Sep 12, 2009 | 01:55 AM
Maybe something went wrong during the install? Am I supposed to delete or move anything after I upload all the definitions? I'm running the newest version of ECUFlash (1.49 I think) and I restarted the program too after I transferred the definitions.
Old Sep 12, 2009 | 02:15 AM
imalancerman's Avatar
sounds like you still need your rom defined, wait for a bit cause you'll get a bite from someone who will define it for you soon. Im sure senate will be more than happy to help. After all, he is the master.
Old Sep 12, 2009 | 06:45 AM
link62's Avatar
why would it need to be defiend still since im the exact same as him an 03 es auto and its works for me, so its not that even in the pic on the left it says 03 auto
Old Sep 12, 2009 | 07:37 AM
darkmitsu's Avatar
your car is using the same xml defs from the lancer oz if you open the xml file that is 81870015.xml you can change the area at the top that says your car name and stuff, also if everything is greyed out you are in beginner mode you need to go into the options and change to developer mode if its still all greyed out your rom is not properly identified...
Old Sep 12, 2009 | 08:00 AM
senate6268's Avatar
Can you post a screenshot just like link62 did so I can see what your ROM ID comes up as? Or send me a copy of your .hex ROM file (my forum name at gmail dot com). Also do what darkmitsu stated - go to File > Options > User Level and change it to "Developer".
Old Sep 12, 2009 | 11:01 AM
You can be in the exact same car and have a different rom id. I didnt think about the developer level though. Its probably just that.
Old Sep 12, 2009 | 12:40 PM
I tried setting the options to developer mode... No luck
Old Sep 12, 2009 | 03:50 PM
senate6268's Avatar
Your ROM is not being correctly identified in EcuFlash. It's defaulting to 81900006. You need to send me a copy of your ROM if you want to be able to use EcuFlash.
Old Sep 12, 2009 | 05:43 PM
So pretty much e-mail you the hex file, right?
