Cat + Exhaust manifold, recommendations
Old Apr 29, 2011, 09:40 PM
Beluga's Avatar
I need to change my front cat on my 2003 lancer oz so I will change both cat and exhaust manifold. Any recommendations?
I am looking for something to pass the emissions without any problems and if possible to gain some power.
Here are couple of options I found online, does anyone have any experience with any of these:
Eastern Front Catalytic Converter, Part #: EAST40674, $365
http://www.autopartswarehouse.com/sk...gs+Best+Seller
Catco Front Catalytic Part #: cat1086, $412
Benchmark Catalytic Converter, Part #: BEN2461, $343
Old Apr 29, 2011, 11:30 PM
Midnightkid's Avatar
Depending on the intensity of the emissions test, you can pass with just about anything as long as you have an O2 Fouler. Changing the Cat won't offer noticeable power gains and in some instances, might rob you of power due to loss of back pressure. In that instance, I'd roll with OEM and I have a Catco OEM Cat Converter. As for Exhaust Manifold, I roll with RRM's 4-1 Exhaust Manifold, but there's other brands like RPW that offer Exhaust manifolds with the downpipe, etc. But unless you plan on going with a full catback exhaust, RRM's should provide sufficient Power gain for an affordable price.
Old Apr 29, 2011, 11:54 PM
Beluga's Avatar
Is this Catco OEM Cat Converter that you recommend:
Old May 1, 2011, 09:46 PM
Beluga's Avatar
bump
Old May 1, 2011, 11:28 PM
Well that's the front cat converter (Header/exhaust manifold). All that is is an OEM replacement. It won't give you any power or anything of that nature. I suggest the Rear Cat Converter, which should be somewhere in the $120-150 range.
Fitted
Jun 4, 2013 01:56 PM
SSickLS1
May 10, 2013 10:31 AM
Jesussaves1
Feb 27, 2013 11:33 PM
Beluga
Lancer Engine Management / Tuning Forums
Jul 4, 2012 02:43 PM
Beluga
Lancer Engine Tech
33
Apr 9, 2012 12:47 AM
Quick Reply: Cat + Exhaust manifold, recommendations
