bad slave/master cylinder? 2002 lancer ls
i was driving on the highway and traffic was slow. i tried downshifting to fourth but the clutch had no feel/pressure. I coasted to the exit ramp and came to a stop. i shut off the car, pushed in the clutch, shifted into gear, and started the car. Immediately the car stalled out. The clutch had no pressure and it was rough shifting into gears. I bled the slave cylinder and pressure was regained in the clutch. A week later the same problem reoccurred. We re-bled the slave cylinder and topped it off with new dot-3 brake oil. Its been a little over a week and roughly 100+ miles since we re-bled the slave cylinder. Is this a cause of air in the system or a faulty salve/master cylinder?
have you changed the slave cylinder on a 2002-2003? i didnt find any leaks on the master or the slave. i took off the rubber seal and put my finger in the housing and didnt find any leaks for the slave cylinder.
I had someone pump the clutch 10x times, had them hold the clutch pedal in, opened the bleeder screw, closed the bleeder screw and then told them to take their foot off the pedal. and i just checked the clutch master cylinder on top of the pedal and it was dry. The car was sitting for about a year, and when we bled it the first time it was completely dirty. Do you think i should just drain the entire brake oil from the master cylinder and put fresh brake oil?
Sounds like your slave. I just today opened my transmission up to find out why I was suddenly losing pressure and leaving a puddle of fluids under my oz. And found my Throwout bering in half. I took pics but don't see where to post them.
weird thing is, it's not leaking oil anywhere. the master cylinder is dry, above the clutch pedal is dry, and the slave cylinder housing is also dry. im thinking since the car was sitting for awhile(maybe 6 months-1 year) that air got in the system. im going to try to take out all of the oil from the brake reserovir and bleed the slave cylinder the right way. what are signs of a bad throw out bearing? much appreciated.
you checked the master cylinder and lines for leaks? is there any fluid dripping from the bell housing? make sure the reservoir does not drop below "MIN" during bleeding, cause if you suck in air from the reservoir, you're back at square one, just press the clutch pedal to the floor slowly while bleeding...
i read a few forums regarding the no pressure/feel from the clutch and a few people mentioned that the bore on the clutch master cylinder was malfunctioning due to highway driving or inactivity of the clutch. the clutch master cylinder didnt not have enough hydraulic pressure to engage the clutch. so i changed the cmc yesterday and the pressure feels a lot stronger than it used to. i havent drove the car on the highway yet to see if it was cmc, but ill post a reply as soon as i go on a long trip.
MisUnderStood
48
Oct 3, 2017 07:57 AM
gooov
Lancer Tranny/Drivetrain Tech
Feb 28, 2015 07:42 AM
Kreeker
Aug 3, 2014 01:17 PM
Rasputin
31
Jul 16, 2012 07:04 PM
