Fuel Pump relay installation direction
I accidentally pulled out one of the fuel pump relays (the bottom one) before noting the direction that the arrow on the relay is pointing. Could someone please check their bottom fuel pump relay and let me know if the arrow is pointing towards the door or towards the center? Thanks
| FP Relay||------------||----------||------------|
|---#1-----||------------||----------||------------|
_________________________________
---Empty---|--------------------------------------|
|FP Relay |--------------------------------------|
|--#2------|--------------------------------------|
********|-------------Fuses------------------|
Above is a diagram of the fuse box right under the steering wheel. The relays are the two black boxes to the left of the fuses, not the ones above. The top one's arrow should point to the right, I need to know the direction of the arrow on Fuel Pump Relay #2, the bottom one. Thanks.
Raceghost
15
Dec 1, 2019 06:34 PM
Lightsaber
Apr 4, 2018 10:02 AM
Mike W
84
Aug 19, 2016 08:36 AM
XinnKoda
Nov 24, 2015 11:16 PM
Aman
Apr 24, 2009 07:40 AM
