Belts
Belts
I installed the under drive pulley about 2 months ago. And now my belts are starting to make a weird noise. I guess it's a squeaking noise. As soon as i put some wd40 it goes away. I turned tigtin the belts some more but no luck. I'm guessing i need a new belt. How much would this belt cost me if i had a shop do it.
as far as i know .. you can change 2 of the belts pretty easy ... if you put on ur pulley by youself you should be able to change your 2 belts ... i have a write up written in the request how to's ... take a look at it ... your save yourself come money ... i know you can get both belts for a little under 40 bucks ....
how do you tighten the belts, i installed the rrm crank pulley with a friend and he did that step. I now were the bolts are to tighten do i just crank on them with a socket clockwise?
orion4096
35
Jan 25, 2016 03:37 PM
