P0304 Miss fire
Old Oct 4, 2012, 02:57 PM
coollol123's Avatar
P0304 Miss fire
Hey Guys!
Today, I was driving to school, and my check engine light went on. When I was getting up to 40 mph. It felt like the car was lagging when getting up to speed. It was doing that lately. So I found out its a
Misfire in Cylinder 4.
Is she in need of a tune-up or a new injector or what?
I have 101k Miles on the car, so I should do a tune-up weather it would fix the P code or not.
Thanks,
-Coollol123
Old Oct 4, 2012, 04:36 PM
coollol123's Avatar
Anyone?
Old Oct 5, 2012, 07:36 AM
03lances's Avatar
All the computer is saying is for some reason #4 cyliinder is not firing correctly. So likely it is either, the spark plug, the coil, or the fuel injector.
If it has been some time since the last tune up I would start there it wont cost much in parts. If you still get the code after the tune up then try swapping the coils around to see if the misfire jumps to a different cylinder.
Old Oct 5, 2012, 11:49 AM
coollol123's Avatar
Okay, now I get it. Thanks,
Ummm As I can tell, This car has probably never had a tune-up. So I'm going to do one. But, before I do, should I change the coil packs cause I mean they are 70 bucks a piece. But, If I don't I wouldn't be doing everything in terms of the Plugs, wires, and stuff.
Thanks,
-Coollol123
Old Oct 5, 2012, 03:10 PM
03lances's Avatar
Thanks,
-Coollol123
You can do plugs and the two wires. No need to change the coil(s) until you identify the problem lies with the coil itself. Coil packs are not a wear item meaning they do not need to be changed out unless there is a problem with them. Unlike plugs, wires, cap and rotor (for distributor which we do not have) which are wear items and need to replaced every so often.
Old Oct 6, 2012, 08:07 AM
coollol123's Avatar
Okay! Thank God. Alright this is the answer I needed! Yeah, Why waste money on the coils if they are not the problem, and you're right, They don't wear.
Thanks A Bunch!
-Coollol123
Old Nov 20, 2012, 07:45 AM
Tye1's Avatar
Any update on this???
coollol123
02-03 Lancer Show / Shine
37
Sep 3, 2012 07:12 AM
coollol123
Jul 12, 2012 12:59 PM
coollol123
May 7, 2012 11:01 AM
coollol123
Dec 22, 2011 03:37 PM
Quick Reply: P0304 Miss fire
