Rough Idle / Engine light on
Old Jun 29, 2013, 07:10 PM
squirrlyj's Avatar
Question Rough Idle / Engine light on
ok so engine light came on today and its had a rough idle for a short while.. ive parked it in the garage so i can pull the mass air flow sensor from my injen CAI and clean it.. also the EGR i plan on cleaning as well, i hope this might fix it. If it doesnt could it be that i need one or more O2 sensors replaced?.. or maybe a vacumm leak?.. anyone else have this before?
Old Jun 29, 2013, 10:45 PM
DVanDuzer's Avatar
Scan the code and tell us what number it is - Will be able to help you more.
Old Jun 29, 2013, 11:28 PM
squirrlyj's Avatar
will do... have to wait til tomorrow to borrow an OBD2 reader
Old Jul 1, 2013, 12:57 AM
squirrlyj's Avatar
Thumbs up Fixed it...
It was a poorly made coil pack that wasnt connecting to the spark plug in cylinder 3 causing it to misfire... code reader said P0303 so i pulled the crappy OBX coil packs out and put the factory ones back.. waste of money... on the other hand at least my engine is running good now
Old Jul 2, 2013, 03:31 PM
squirrlyj's Avatar
still getting a rough idle
guess the rough idle is still there but no engine light anymore, gonna have to check all the sensors and vacuum lines i guess.. im wondering maybe if it could just be worn motor mounts or something
Old Jul 2, 2013, 05:56 PM
Automatic 51's Avatar
Did you disconnect the battery when you put the stock coil packs back on? If not do that, let sit disconnected for 10 min then reconnect and let idle for 20 min or so.
Otherwise you might have fouled the plugs possibly. Motor mounts are a possibility too.
Old Jul 6, 2013, 02:15 PM
squirrlyj's Avatar
nothing wrong with the stock coil packs or plugs.. it was the crap OBX makes that was causing the misfire.. never buying anything obx again.. everything working fine now, only getting vibration from engine at random times... has to be a mount i can find no other problems
Old Jul 6, 2013, 03:10 PM
eusgen's Avatar
Have you tried this yet? resetting the ECU can help sometimes
XinnKoda
Lancer Troubleshooting
Apr 14, 2019 12:27 PM
hurdle18
Feb 23, 2015 07:26 AM
JTCB
May 31, 2014 07:22 AM
EvoAirRick
Apr 25, 2013 05:50 AM
Fifty
Feb 12, 2010 02:39 PM
Quick Reply: Rough Idle / Engine light on
