Anyone running AP Pro Radi Cal brakes
Old Mar 9, 2016, 07:43 AM
  #31
Robevo RS's Avatar
Originally Posted by honda-guy
im looking at relocating my ACD to the rear this year also. gotta look up the rules about having flammable fluids in the car. also rewire for ACD tuning.
put it behind the Co-driver seat
also my suggestion if that matters in anyway, to get a ACD Gems / Motec / Pectel ECU if that works with your current engine ECU. Plug and play the gems and the Pectel, dont know about the motec. And i might can help you to get a pro team tested map for you for tarmac
Old Mar 9, 2016, 09:04 AM
  #32
SWOLN's Avatar
Originally Posted by Balrok
Just got the marketing email about em...for EVERY corvette/M3 etc out there...no Evo love. If I can get a count of who's genuinely interested we may be able to sway them. Esp a rear kit.
I'm interested.
Old Mar 9, 2016, 12:18 PM
  #33
Balrok's Avatar
So lets format it so we know what we all want, I'll start
Fronts: Current 8350 upgr to RadiCal kit
Rears: AP xyz
ABS: yes
ParkingBrake: no
MasterCyl: OEM
Old Mar 9, 2016, 02:16 PM
  #34
SWOLN's Avatar
Front: Current 8350 upgrade to Radi-CAL Kit
Rears: AP xyz
ABS: Yes
Parking Brake: Yes, can remove
Master Cylinder: OEM
Old Mar 9, 2016, 08:43 PM
  #35
Grimgrak's Avatar
I'd get the diamond front subframe too makes servicing the clutch much easier. As well as weight savings.
Old Mar 10, 2016, 04:30 AM
  #36
Shiroi Kitsune's Avatar
Flammable fluids in the passenger compartment are frowned upon by most sanctioning bodies lol.
Old Mar 10, 2016, 08:23 AM
  #37
Balrok's Avatar
On the wish list.
Old Mar 10, 2016, 11:57 AM
  #38
SWOLN's Avatar
Got an email back from AP Racing.
" Nothing listed by APR Factory to date for the Evo competition kits using the new Pro 5000R range.
But contact UK distributor, they are devising new kits using this new caliper range."
Thank you,
Peter Collen
Old Mar 10, 2016, 05:49 PM
  #39
Balrok's Avatar
Hit em up, see what they say.
Old Mar 10, 2016, 07:37 PM
  #40
SWOLN's Avatar
In motion
Old Mar 21, 2016, 10:50 AM
  #41
SWOLN's Avatar
This is the caliper that we would be using if we move forward. Rear's will be developed when I tell him if we are using a cable or hydraulic hand brake. Thoughts?
http://www.apracing.com/product_deta...thick_pad.aspx
They would use 362x32mm discs.
Old Mar 21, 2016, 12:11 PM
  #42
Balrok's Avatar
Hmm, to make things cheaper i'd opt to delete the handbrake all together. But since the rotor sits so far back from the hub anyway it may just require the odd shaped hat regardless. If we can simply use our 8350's in rear with smaller pistons that'd help immensely with costs.
Old Mar 21, 2016, 12:46 PM
  #43
SWOLN's Avatar
For safety reasons would you really want to delete it? Is the handbrake required in any rules? Just thinking ahead a little for others who may want in.
Old Mar 21, 2016, 02:31 PM
  #44
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
Our hand brake is a joke. A friend tried to use it in his car for drifiting. From 60mph, the car slowed down maybe 10mph, then they just started smoking and the car quit slowing down...lol
Old Mar 21, 2016, 05:43 PM
  #45
Balrok's Avatar
LoL deff not, which is likely why he's asking if we're using Hydro brakes which is the real deal for drift/rally. Only time I ever used the hand brake was loading in the trailer. If you try using that at speed on track you may find yourself kissing tire walls.
Quick Reply: Anyone running AP Pro Radi Cal brakes
