DMT tuning 👎🏿👎🏾👎🏻👎🏽
Old Nov 2, 2016, 12:53 PM
FstAsVR4's Avatar
DMT tuning 👎🏿👎🏾👎🏻👎🏽
I know this will be just the tip of the iceberg but here it goes. I had Danny tune my car after hearing mostly good things about him a few years back I had a 2.1 with a 6266 on her he did some base tuning and adjustments then we were off doing pulls well the second pull it starts making a noise which I thought was rod knock he said no it's a lifter I pulled the valve cover off and looked didn't see anything crazy so I replaced all the lifters just in case. Turned it back on and still the noise was there I dropped the pan and sure enough spun bearings i tear the motor down and found it had some bad detonation going on as well. Since I bought the car with this motor I assumed it was just bad luck i then build the motor to a 2.4 i oring the block and all. Have him tune it again and the power isn't there the drivability sucks just all around a **** car i get it a little better with some research and then sell the car less than 4K on motor the new owner then gets a retune and advises me that the knock sensor was turned off and then the motor let go he tears the block down and sure enough same issues that I saw on the original motor. I know of a lot of people in the Orlando area where this has happened to them as well. Just want everyone to be careful and please find a better person to tune your vehicle.
Old May 19, 2017, 03:44 PM
EVOX_29's Avatar
dmt sucks. buddy of mine is going threw an issue right now with a build and tune he did. basically car lasted 2k miles then started to have leak down issues. and the horror stories with dmt just keep piling up.
VQChris
Aug 27, 2017 07:05 PM
NFSLancerRA
Evo X Dyno Results
19
Apr 24, 2015 12:30 PM
mrfred
25
Mar 10, 2015 09:10 AM
mrfred
Sep 23, 2014 09:28 PM
koreanostrich
Jun 24, 2012 06:38 AM
Quick Reply: DMT tuning 👎🏿👎🏾👎🏻👎🏽
